Page 19 of 26 FirstFirst ... 91718192021 ... LastLast
Results 181 to 190 of 253
Thread: Razor80 Stage 3 Allspace R Build
  1. #181
    Quote Originally Posted by INASNT View Post
    Spacer wont help, Gordie tried to code my CEL out multiple times but it still come up every few weeks, sometimes goes off by itself after a few days..
    Seems to be a Tig specific thing not being able to code out fully
    I had it coded out with the first low boost file which was written by RD Technik so it can be done. Putting a spacer in is a bit of a pain because of the location of the O2 sensor means the DP really has to come out to fit the spacer.
    Quote Originally Posted by iDiesel View Post
    Isn't emissions related to fuel efficiency, i.e. the less fuel used the the less emissions?
    Yes and no. The main measurement used for emissions is g/km of CO2. So yes if you're using less fuel then more than likely you're producing less CO2/km.
    There's a few other components other than CO2 that are looked at and that includes CO, total hydrocarbons and NOx. These will depend on how well your catalytic converter is operating, what the combustion and exhaust temperature is and probably a host of other factors.
    Even though you may produce fewer CO2 emissions and use less fuel, more than likely this will have an adverse effect on some of the other emissions.
    Aug 2018
    Yeah, and I guess the temptation to give a few beans a bit more often may undo some of that
    2018 Allspace 162TSI R Line
  4. #184
    Sep 2011
    Melbourne, Victoria
    Can be installed without removing the downpipe, did mine but was quite hard...
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
  5. #185
    Yes it's in a pretty hard to get to place. Requires small hands and a lot of patience.
    Oct 2018
    Melbourne, VIC
    Quote Originally Posted by Razor80 View Post
    Just an update on fuel consumption.
    Yesterday some earlier short blasts and downshifting average comsumption is 10.6. Evening long journeys with family (cruising) so no on boost and average consumption sits at 7.2. Which is actually better then I normally had when on the standard setup which is strange but I guess everything is finely tuned and air/fuel mix is spot on.
    What was your daily average if you’re now at 10.6?
  7. #187
    May 2019
    Melbourne, Vic
    Quote Originally Posted by PDMJO View Post
    I was getting around 7.6 cruising and around 11.5 with some blasts. Car is regularly serviced and fluids checked so with was surprised after new setup it improved.
    2018 Tiguan Allspace R-Line - Platinum Grey Metallic
    Stage 3 - Snail IS38 Hybrid Turbo - Etuners Motorsport - 265.5awkw's
  8. #188
    May 2019
    Melbourne, Vic
    Hi guys this is the drone that I am getting. Definitely from axle back but is 10x louder in the car when driving. However the pops and crackles sound nice with the turbo flutter
    Dropbox - 20190708_183728.mp4 - Simplify your life
  9. #189
    Sep 2011
    Melbourne, Victoria
    Cant tell much from the sound clip. Clamp to rear muffler might be loose
  10. #190
    May 2019
    Melbourne, Vic
    Will have to take it somewhere to check. Could have a split or could be the clamp you mentioned thanks.
