Page 9 of 26 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 253
Thread: Razor80 Stage 3 Allspace R Build
  1. #81
    Quote Originally Posted by Razor80 View Post
    Anyway my question - What are the original calipers on the Tiguan/Golf R's?
    After much googling, I can't find much information if they are 1 large piston or 2 piston for fronts, rear is 1 piston I think judging by images? I think the rotor size Front 340x32 & Rear 312x12?
    Tiguan/Allspace 162 are front: 340x30 and rear: 300 x 12
    Golf R are front: 340x30 and rear: 310x22
    The calipers on the Golf R are different though. Pretty sure both are 2 pot (1 larger piston each side).
    The Racingline are only 345mm discs so the actual braking performance is not significantly better than stock (marginal), however they do claim that repeated braking is greatly improved in terms of repeated stops.
    The Alcon 4 pots are 355mm so you probably would notice a slight improvmenet with these and again it's going to be the repeated applications where the aftermarket kit is going to be an advantage.
    This probably moreso comes down to the pads and how well the pads are able to cope with high temperatures without breaking down.
    May 2019
    Melbourne, Vic
    Thanks for clearing that up - Interesting why they put a skinner rotor on a heavier car! Or are the Tiguan's meant to be stock standard.
    So in saying this B/D was suggesting this if I was upgrading the rear rotors and pad https://brakesdirect.com.au/aus/f2d-350-22-aar-r-forza-2-piece-brake-disc-350mm-upgrade-including-red-carrier-right.html so this wouldn't fit if this is much thicker or is that what the carrier is for the adaption?
    I found these guys that have the Wilwoods -
    and these guys have the Brembo or AP Racing -
    Race Brakes Sydney | Brakes so will get some pricing and see what they can do. Is there a maximum rotor size on the 4 piston setup?
    2018 Tiguan Allspace R-Line - Platinum Grey Metallic
    Stage 3 - Snail IS38 Hybrid Turbo - Etuners Motorsport - 265.5awkw's
  3. #83
    May 2019
    Melbourne, Vic
    *Tried to edit my comment above but crashed*
    So in saying this B/D was suggesting this if I was upgrading the rear rotors and pad F2D.350.22.AAR-R | Forza 2 Piece Brake Disc 350mm Upgrade Including RED Carrier (Right) so this wouldn't fit if this is much thicker or is that what the carrier is for the adaption?
  4. #84
    May 2019
    Melbourne, Vic
    It won't be long until your itching to install it all. I will be faced with the same issue, how am I going to hide all the extra power and sound once it's done hmmm lol
    Congratulations with your newborn - Precious times ahead .
    Yes my tuner 2-3 days but has offered a runaround for the duration but I can hire a family car through my cousins work to make it more practical to pickup my daughter from childcare. See if they can offer that, no harm in asking.
    I'm getting some assistance on my other thread, 6 piston an overkill but rotor size on 4 pisions not big enough.
    I wonder if the Golf R wagons would fit straight on since there slighly longer or perhaps the Passat? Would solve extending the tips.
  5. #85
    To be honest If you're not going to go much bigger than the 340mm stock front brakes you may as well just upgrade the pads/rotors and be done with it. It really depends what you're chasing. 2 piece rotors will be lighter than the stock set-up so will reduce the rotating mass which is always a good thing. The stock calipers are pretty damn heavy too as they're cast stainless and weigh a ton. That being said you're driving an SUV so if you were really concerned about weight you'd be driving a hot hatch.
    The 1 off braking performance between a 340mm stock set-up and a 345mm 4 pot you probably wouldn't notice. You'll pay a fair bit to change them over which is why I'd suggest just doing a pad/rotor change (optional) and paint them.
    Unless you're going to significantly larger rotors you won't be achieving much in terms of better braking because you need the larger diameter and bigger contact area to make a noticeable difference.
    So I'd either hunt around for some second-hand 4 pots if you really want to change the calipers or save up for a 380mm 6 pot set-up.
    Even if you're doing some happy laps on the track a pad upgrade is probably all you really need.
    The other thing to consider (and it's more of an issue on the Golfs) is if the larger brake calipers will fit under your wheels. I know a few people that have tried (and failed) to fit BBK's on Golfs and then had to fit spacers/got into problems with wheel poke and then had to get new wheels to fix the poke problem. It's less of an issue on the Tiguan due to the car running 10+mm more offset than Golf but something to keep in mind.
    Mar 2019
    considering the stock brakes will trigger the ABS when the tyres start to slip, surely the tyres are the limiting factor for stopping the car....
  7. #87
    Quote Originally Posted by MickyD View Post
    Actually the brakes make a decent difference. ABS only really kicks in at lower speeds but the brakes will wash off the vast majority before they "lock":
    Attachment 46504
    Attached Thumbnails Attached Thumbnails Razor80 Stage 3 Allspace R Build-stopping-distance-png
    Jan 2019
    The Golf R wagon mufflers are split, and the way they are routed with the downpipe is different as well, so that's a no go.
    Tigger posted an under car shot of one in the exhaust thread.
    I can't comment on the Passat but pretty sure it's also incompatible.
    Those that have done the muffler swap have nothing but good things to say about it, and how simple it is.
    I've been reading the brake discussion with interest.
    I definitely think the rotors need to be replaced, front and rear, as the OEM ones are soft.
    Perhaps a combination of a good aftermarket rotor and a good set of grippy pads is the solution, but I can't deny seeing a pair of 6 pots on the Tig gives me a stirring, haha.
    Sent from my Pixel 3 using Tapatalk
  9. #89
    Final mods to be installed. Estimated power figure to be around 270-280kw's (362-375BHP) @ wheels. Should go really well
    Snail IS38 480HP Hybrid Turbo
    CTS MQB Downpipe with Magnaflow 200 Cell Catalyst
    CTS 600 Intercooler
    CTS Air Intake
    CTS Intake Elbow
    CTS Dog Bone Insert
    Turbosmart Dual Port DV
    Stage 3 ECU & DSG tune
    Apparently the stock pump is still good unless I chase more power. I will update the cat-back exhaust later down the track with the MK7 Golf R system (seen on other threads that this fits) as I don't want the annoying drone sound and will extend to the tips.
    Can you guys think of anything I could consider adding or changing???
    I thought about getting the P3 multi vent gauge if this will fit the Tiguan vent (hopefully not too complicated), or best using OBDEleven apps to monitor things?
    Your list looks solid. Don’t forget good spark plugs! I changed my flappy paddles to the racing line ones...they are very awesome, feels more like a solid rs feel.
    If you have any power/time stats after install I’ll post them on the is38 and big turbo front page/summary thread.
  10. #90
    May 2019
    Melbourne, Vic
    Ahh that's a real shame, thought that'll be a easier fix with one of those back boxes. The Golf R it is then...
    This discussion on the brakes is really twisting my brains, I know what I want and what I don't want is to replace it all after a few months if I opted for just pads/rotors. I might have to "bite the bullet" and order it so I can't change my mine. Being a Gemini is hard work lol
