I found these guys that have the Wilwoods -and these guys have the Brembo or AP Racing -Race Brakes Sydney | Brakes so will get some pricing and see what they can do. Is there a maximum rotor size on the 4 piston setup?
Tiguan/Allspace 162 are front: 340x30 and rear: 300 x 12
Golf R are front: 340x30 and rear: 310x22
The calipers on the Golf R are different though. Pretty sure both are 2 pot (1 larger piston each side).
The Racingline are only 345mm discs so the actual braking performance is not significantly better than stock (marginal), however they do claim that repeated braking is greatly improved in terms of repeated stops.
The Alcon 4 pots are 355mm so you probably would notice a slight improvmenet with these and again it's going to be the repeated applications where the aftermarket kit is going to be an advantage.
This probably moreso comes down to the pads and how well the pads are able to cope with high temperatures without breaking down.
2018 Tiguan Allspace R-Line - Platinum Grey Metallic
Stage 3 - Snail IS38 Hybrid Turbo - Etuners Motorsport - 265.5awkw's
*Tried to edit my comment above but crashed*
Thanks for clearing that up - Interesting why they put a skinner rotor on a heavier car! Or are the Tiguan's meant to be stock standard.
So in saying this B/D was suggesting this if I was upgrading the rear rotors and pad F2D.350.22.AAR-R | Forza 2 Piece Brake Disc 350mm Upgrade Including RED Carrier (Right) so this wouldn't fit if this is much thicker or is that what the carrier is for the adaption?
It won't be long until your itching to install it all. I will be faced with the same issue, how am I going to hide all the extra power and sound once it's done hmmm lol
Congratulations with your newborn - Precious times ahead .
Yes my tuner 2-3 days but has offered a runaround for the duration but I can hire a family car through my cousins work to make it more practical to pickup my daughter from childcare. See if they can offer that, no harm in asking.
I'm getting some assistance on my other thread, 6 piston an overkill but rotor size on 4 pisions not big enough.
I wonder if the Golf R wagons would fit straight on since there slighly longer or perhaps the Passat? Would solve extending the tips.
To be honest If you're not going to go much bigger than the 340mm stock front brakes you may as well just upgrade the pads/rotors and be done with it. It really depends what you're chasing. 2 piece rotors will be lighter than the stock set-up so will reduce the rotating mass which is always a good thing. The stock calipers are pretty damn heavy too as they're cast stainless and weigh a ton. That being said you're driving an SUV so if you were really concerned about weight you'd be driving a hot hatch.
The 1 off braking performance between a 340mm stock set-up and a 345mm 4 pot you probably wouldn't notice. You'll pay a fair bit to change them over which is why I'd suggest just doing a pad/rotor change (optional) and paint them.
Unless you're going to significantly larger rotors you won't be achieving much in terms of better braking because you need the larger diameter and bigger contact area to make a noticeable difference.
So I'd either hunt around for some second-hand 4 pots if you really want to change the calipers or save up for a 380mm 6 pot set-up.
Even if you're doing some happy laps on the track a pad upgrade is probably all you really need.
The other thing to consider (and it's more of an issue on the Golfs) is if the larger brake calipers will fit under your wheels. I know a few people that have tried (and failed) to fit BBK's on Golfs and then had to fit spacers/got into problems with wheel poke and then had to get new wheels to fix the poke problem. It's less of an issue on the Tiguan due to the car running 10+mm more offset than Golf but something to keep in mind.
considering the stock brakes will trigger the ABS when the tyres start to slip, surely the tyres are the limiting factor for stopping the car....
Actually the brakes make a decent difference. ABS only really kicks in at lower speeds but the brakes will wash off the vast majority before they "lock":
Attachment 46504
The Golf R wagon mufflers are split, and the way they are routed with the downpipe is different as well, so that's a no go.
Tigger posted an under car shot of one in the exhaust thread.
I can't comment on the Passat but pretty sure it's also incompatible.
Those that have done the muffler swap have nothing but good things to say about it, and how simple it is.
I've been reading the brake discussion with interest.
I definitely think the rotors need to be replaced, front and rear, as the OEM ones are soft.
Perhaps a combination of a good aftermarket rotor and a good set of grippy pads is the solution, but I can't deny seeing a pair of 6 pots on the Tig gives me a stirring, haha.
Sent from my Pixel 3 using Tapatalk
Your list looks solid. Don’t forget good spark plugs! I changed my flappy paddles to the racing line ones...they are very awesome, feels more like a solid rs feel.
If you have any power/time stats after install I’ll post them on the is38 and big turbo front page/summary thread.
Ahh that's a real shame, thought that'll be a easier fix with one of those back boxes. The Golf R it is then...
This discussion on the brakes is really twisting my brains, I know what I want and what I don't want is to replace it all after a few months if I opted for just pads/rotors. I might have to "bite the bullet" and order it so I can't change my mine. Being a Gemini is hard work lol
