Page 7 of 26 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 253
Thread: Razor80 Stage 3 Allspace R Build
  1. #61
    May 2019
    Melbourne, Vic
    Thanks for that Lucas_R. Wow they really are renowned for their performance and quality values. Maybe in the car fanatics area I was exposed too, I didn't get to see this in action or being recommended.
    I prefer to purchase brand new components and if I went the Golf R or RS3 setup these would be (im guessing) hard to find and/or almost as expensive as the Alcon setup? What size afe these standard anyway?
    The guy told me that these kits will fit straight on but would need to order custom hats and brackets which can take 4-6 weeks.
    Does anyone know where I can get aftermarket kits fitted in Melbourne?
    2018 Tiguan Allspace R-Line - Platinum Grey Metallic
    Stage 3 - Snail IS38 Hybrid Turbo - Etuners Motorsport - 265.5awkw's
  2. #62
    May 2019
    Melbourne, Vic
    Also what setups is good for the rears or will the standard OEM setup be sufficient for what I intend to use it for? Im guessing it'll need to be compatible with the electronic handbrake?
  3. #63
    Rays Big Brakes
    Quote Originally Posted by Razor80 View Post
    Hardest park is finding something compatible with the electronic handbrake. You're better off going with a pad (and rotor?) upgrade for the rear only. Pads have the most effect and rotors just for looks
    I'm getting a set of the Alcon 6 pots with DBA T3 rotors fitted up tomorrow.
    May 2019
    Melbourne, Vic
    Thanks tigger73, I was thinking pads for the rear as being an easier option. I can see this rear clipper being a headache!
    That's exactly the colour caliper I was looking at, don't won't the red or black standing out too much and would blend better with the rear.
    What size rotor have you gone for with the DBA? What pads are you planning to use?
  5. #65
    They’re a 378mm rotor. Not sure on pads will find outplayed today as the workshop I go to (Haines Mechanical & Detail) is fitting the kit.
    Brake calipers have actually been painted since this pic. Long story short the brakes had been bought in and repainted for another customer who ended up not going through with the install.
    Mar 2017
    Tasmania
    Fitting larger capacity calipers won’t help you if the master cylinder isn’t up to the task. Larger calipers (greats number of pistons, larger piston volume) require a larger amount of fluid to be pumped to them to result in the same clamping pressure. There will be slight variations due to a larger swept area producing greater friction with less clamping pressure, but unless the factory master cylinder is up to the task you’re asking of it, then you’re going to require higher pedal pressure to achieve the same clamping pressure (you have to push the pedal harder than you do now to get the same stopping power), and ultimate braking capacity could quite possibly be reduced.
    Physical fit is only one of the factors to consider. Arguably the most important one - compatibility of the replacement calipers with the factory master cylinder - is the one most often overlooked.
    May 2019
    Melbourne, Vic
    Quote Originally Posted by doc_777 View Post
    Thanks doc_777. This is what I am concerned about whether the standard hydraulic system will be adequate once fronts are upgraded. Will the rears loose pressure or vice versa?
    Ive spoken to George at Alcon and he's positive these will be fine on the MQB standard system. So now im confused!
  8. #68
    Just fitted a set of Alcon 6 pots up today and can confirm a few things:
    1) Tiguan uses the same brake master cylinder as Mk7 Golf R.
    2) The actual volume of the 6 pots isn’t massively different than the stock brakes as there’s 6 smaller pistons instead of 2 larger ones on the stock brakes.
    3) The Alcon brakes and rotors are lighter than the stock setup (even though they are bigger).
    I do have a bit more pedal travel before the brakes bite but need to bleed the brakes again. Also need to do a few 100-0 stops to get them properly bed in. Fronts do pull up harder
    May 2019
    Melbourne, Vic
    Thanks again tigger73 - You always return with some reassuring advice.
    By the looks of the pistons they look like there staggered in size rather then the same size for all six. I'm guessing this is the help with the BMC with fluid pressure?
    Hopefully once you've bleed them and bedded them in the pedal feel will improve. Are you keeping your rears stock? I'm not sure whether to change the pads and leave the standard rotors to gain a better response from them.
    Btw - Howlong did your order take from ordering to being delivered?
  10. #70
    Rays Big Brakes
    Not 100% sure but I’ve seen it on a few 6 pot brakes. Probably because this gives more even wear and best performance/feel??
    I’ll possibly upgrade the rears with pads/rotors at a later stage. Pads can give you better initial bite if that’s what you’re after. Also some people change to ATE ceramics for less dust.
    These are normally around 4 weeks for the calipers plus a few days for painting. All the rotors/pads/hats etc are off he shelf items locally.
    My workshop had these from a cancelled customer order so I was able to pick them up and get fitted without having to wait.
