Page 1 of 26 12311 ... LastLast
Results 1 to 10 of 253
Thread: Razor80 Stage 3 Allspace R Build
    May 2019
    Melbourne, Vic
    Talking Razor80 Stage 3 Allspace R Build
    Allspace build Specs summary:
    Snail Turbo IS38 480HP Hybrid
    CTS 3" Downpipe 200 Cell Cat
    CTS 600 Intercooler
    CTS Intake Elbow
    Intergrated Engineering CAI
    NGK RS6 Spark Plugs
    CTS Dog Bone Insert
    Stage 3 ECU & DSG Custom Tune
    As of 4th July 2019:
    1st Stage 3 Tiguan Allspace in Australia and possibly worldwide.
    265.5KW @ all wheels, 465Nm Torque running at 26-27psi.
    Launch Control set at 16psi in 1st gear, limiter set at 4000rpm.
    Tuner - Gordie @ Etuners Motorsport Dandenong.
    MK7 R Rear Muffler with extended tips.
    Soon to Install (on order):
    Front - Alcon 6 Piston with 378x32mm Forza Rotors with FP3 Pads
    Rear - Forza 350x22mm Rotors using existing Electronic Caliper with FP3 Pads
    Future Plans:
    Repaint existing R-Line wheels or lighter wheel replacements.
    Water/Meth Injection (Big maybe and only if tracking it)
    Oil Cooler (again if tracking it)
    Razor80 Stage 3 Allspace R Build-20190704_193551-jpg
    May 2019
    Melbourne, Vic
    Attachment 46674Attachment 46675
    Final result from tonight - This sleeper really goes well, will surprise some. Will upload a vid soon
    May 2019
    Melbourne, Vic
    Arrow Razor80 Stage 3 Allspace R Build
    Hi guys,
    I would like to get have the following done on my 2018 Tiguan Allspace:
    CTS Intake (or similar)
    CTS Downpipe and HI flow Cat (or similar)
    Redirected BOV
    ECU & DSG tune
    I've heard good things (through O/S mates) and read about the JB4 plug & play from this forum, which I like the idea off. Especially for warranties as I still have 3 years left and it is also my first new car.What mod's won't void my warranty or all of the above will anyway?
    I'm a little stuck in deciding whether stage 1 just a tune or stage 2 (as above) or 3 (bigger turbo and cooler)? I'm more inclined to go stage 2 or 3 tbh. If I had the full exhaust setup as well would it need to custom lengthened as the Allspace is longer and it'll look so much nicer coming through the fake crappy blanks?
    I'm looking getting these done in the next few weeks. Does anyone have any success or regrets with any tuners in Melbourne?
    Jan 2019
    Those mods will void your warranty, even just a stage 1 tune.
    The JB4 won't as it's a plug and play unit.
    If you do decide to get a tune (stage 1 or 2), I recommend Etuners.
    I've used them here in Sydney on my previous car.
    Sent from my Pixel 3 using Tapatalk
    Oct 2015
    Hardware changes you mention will void all the drivetrain (engine, gearbox, axles, haldex, hubs/bearings, brakes, most suspension components)
    The plug in module, I can’t say. Depends if vw can data trace anything that proves it was installed and for how long?
    May 2019
    Melbourne, Vic
    Thanks for your responses guys. Sounds like they "go to town" in regards to warranties etc.
    If I done all the above apart from the DSG tuning then that'll mean only engine not covered - Correct?
    Engine and drivetrain warranty will (potentially) be affected.
    My thoughts on this are that you've already got 30,000km on the clock and if you were going to have a manufacturing fault it would have shown up by now. If you look at the number of problems/failures with 162TSI engine/drivetrain on here it's very, very small (almost zero).
    I'm not saying to do it - it's a risk that each individual has to take themselves. Some people choose to do it and others wait until after warranty. My thoughts on the warranty thing is that if you wait until after warranty expires to tune it then if you break it you're still up for the cost of repairs. So if you're going to tune it anyway then there's actually no benefit in waiting (other than to be sure there is no factory issues).
    The thing you're sacrificing is a couple of years of warranty (free repairs if anything fails) vs. putting a smile on your face every time you drive your car.
    Actually you'll still have warranty on most items - just not your engine/transmission.
    Oct 2015
    No
    Engine is a key component to the driveline.
    More overall power, rev increase, torque limits removed certain gears, different power/torque curves, etc COULD contribute to premature failure of any component within(maybe beyond) the list I mentioned earlier.
    Unlikely with normal driving (but then, why do it...), but possible- and therefore an easy ‘out’ for any manufacturer in a warranty claim.
    May 2019
    Melbourne, Vic
    That's what I was thinking also....
    Ive' already done nearly 30000km and if I had major issues it would've already happened. I was more concerned about the DSG issues that the 6 speed or older versions had but I haven't seen (touches wood) such issues to date so must be ok. To be honest the only issue I had was the centre mirror/camera/sensors had to be re-aligned from date of collection.
    The other thing of concern, that if I waited after warranty the period car might be more at risk of failing due too higher mileage (roughly 60-80000kms) and then be faced with huge repair bills.
    Like I said earlier, I love the car, it looks mean from the front, handles pretty well (in normal mode), comfortable and has some nice touches plus the extra space in the boot for the pram etc. Now I need some extra fun factor to complete the package
    May 2019
    Melbourne, Vic
    Thanks for this valuable info Simonr23, will keep it all in mind. It's my daily car and I have pushed the car on more then a few occasions since the safe period of running it in from new. I always check fulid levels weekly and listen out for rattles etc and 30000kms on it's like new. Always wait for turbo to cool too, I don't turn engine off
    I realised I needed extra power when a little Ford RS came along and although I was still with it, it'll been nice to kiss it good-bye! It was going fine until he turned flicked his anti-lag on and it was all over!!!
