Originally Posted by
Boosted_GP
Howsit Razor80.
With the allspace fid you need to extend the pipe between the dp and the back box?
Want to do this mk7R mod on my car but not sure if it will fit due to the Allspace being 200mm linger than the std Tiguan
Hi Boosted_GP - The MK7 R muffler will fit straight on with maybe a slight bit of welding to attach it to the existing system. The brackets all line up perfectly so no issues in terms of fitment. You just need to extend the twin pipes each side if you would like them seen through the chrome trim surrounds. If not you could easily have downward firing like the standard Allspace with possibly the same sound effect.
2018 Tiguan Allspace R-Line - Platinum Grey Metallic
Stage 3 - Snail IS38 Hybrid Turbo - Etuners Motorsport - 265.5awkw's
