Before I finalise my brakes order today (it wasn't mentioned to me) but I thought I will check if these pads have the sensors built in or do they do not? If not, how do I avoid the car detecting a problem with the wear sensors?
2018 Tiguan Allspace R-Line - Platinum Grey Metallic
Stage 3 - Snail IS38 Hybrid Turbo - Etuners Motorsport - 265.5awkw's
Thanks mate, I forgot to mention it's sorted. I was advised the rears don't have sensors and but the fronts on the other do. The front pads come with sensors so should be no issues.
My brakes are now ordered, now the painful wait for them to arrive. The rears on the other hand will come this week, so least I have half my birthday present to myself haha.
The guys at Brakes Direct are really great, can't recommend them enough.
I purchased the following:
Alcon 6 piston Advantage Extreme with DBA 5000 series 378x32 T3 slotted rotors (this design to match the rears pattern)
Forza 2 piece brake kit 350x22mm - Using existing calliper
Pads all round - Forza FP3's - Still good for street/track
I will post a pic of the rears once received.
BTW - My rear calliper is getting repaired next week so will book in with Gordy soon. Get you maps soon after![]()
Nice set-up. So how do you fit 350mm rotors on the rear using the existing caliper? Do you need a caliper relocation kit? Interested in this option as I have currently left the rears stock.
I'm patiently waiting for yours to get tuned as they'll update my file once they've sorted out some of the challenges with the ECU that they're experiencing. Easier to do it with the car on the dyno in Melbourne and means that my local guy doesn't have to get involved with loading a heap of revisions while they work their way around the engine protection limiting boost.
The rear Forza kit comes with a brackets for the adaption. This allows 350mm rotors to be used with OEM calliper.
Here's a link to the kit F2D.350.22.AAL-B | Forza 2 Piece Brake Disc 350mm Upgrade Including BLACK Carrier (Left)
What sort of issues are they experiencing with the ECU or limited boost? Are you now going to get your DSG tune once its remapped?
Forgot to mention - There is a left and right set, so you have to purchase it together of course
Think the link didn't work, here it is again.
Something else for the shopping list... be interested in your feedback.
No problems but will get these fitted once I receive the fronts as I don't want to have to bleed the brakes 3 times and paying to get it done twice.
The brackets in the above kit comes in either black or red.
How are you finding your fronts now, should be bedded in properly by now?
