Originally Posted by
NZ_GolfR
So I think I have managed to have some success here with activating this wit the R-Line LED lights. Here is what I have done (using OBDeleven):
Make sure Lights are switched off
Control Unit:
Central Electronics (Hex09)
Adaption - Fernlicht_assistent - Menuesteuerung Fernlichtassistent: Change to
Present
Adaption - Fernlicht_assistent - Erweiterte_Frenlichtsteuerung: Change to
AFS, FLA, Fernlicht ueber AFS (mine was originally set to: AFS, Fernlicht ueber AFS) - This was the important change that wasn't documented anywhere else and seems to stop the rest of the coding from working.
Coding
- Long Coding - Byte 2: Change to
Hex3 (Bit 0=1, Bit 1=1)
Control Unit:
Front Sensors Driver Assistance System (HexA5)
Coding -
AFS_coding_Light_assist: Change to
High_Beam_Assist (Long coding Byte 21 - Hex 20 (Bit 5=1))
Once I had done this I now have Light Assist showing in the Car Settings Menu under Light Settings:
Attachment 29242
And when I flick the lights stalk forward I get the Light with A in it showing on the AID:
Attachment 29243
Now I just need to test to see how well it works....
Thanks for this mate! Have you tested and confirm that it works? Does it only gets triggered when above a certain speed? Is it possible to adjust that?
'17 MY18 Skoda Octavia vRS 169Wagon | Quartz Grey | DSG | Tech Pack | Luxury Pack | Panoramic Sunroof | Electric Tailgate
OBDeleven'ed: High Beam Assist | Comfort Blink Cycle x 4 | DRL On/Off | Traffic Message Channel | HVAC Auto Fan Speed Display | HVAC Recirculation Memory | Maxidot: Refuel Amount, Lap Timer| Tailgate Closing via Interior Button| Remote Tailgate Closing | Easy Entry/Exit | Comfort Sunroof Opening | Acoustic Lock/Unlock | Dynamic Brake Lights
[Retired] 2010 MY09 BMW E90 320d M Sport | 2004 MY04 BMW E46 325i M Sport
