Thank Glad, thats nice , ill order it soon and ask you how ...hehe ...
Printable View
Thanks for that NZ_GolfR - very helpful.
My only concern is coding the Central Electrics module Byte 2 using VCDS, as I have no reference of what to go back to should something go wrong - see my post about showing all zeros.
Does OBDeleven show the coding for that module?
Is your module the same part number (5Q0 937 084 CF)?
It also keeps a history of all your changes so you can easily see what you have done to then go back and undo the changes. Or in my case see the changes made so I can then write up the details for everyone here without having to sit in my car (my wife already looks at me funny for the amount of time I spend in my car without going anywhere [emoji3])
Thank you NZR -- I like .......hehe
Thanks for everyone's help - I have got High Beam Assist to work a treat!
I followed NZ_GolfR instructions, however I found that I did not need to code Byte 2 on my BCM (09) module - just left it as found - just adjusted adaptations as per instructions and coded A5 Byte 21.
Have not been able to find the speed adaptation as yet, so it activates at about 65kmh at the moment. Does not appear to be in module A5, but probably in 09.
Module A5 is "Front Sensor Driver Assistance" which controls the camera in the front it uses to dip the headlights as well as Adaptive Cruise Control. Depending on the model you have you might not have this camera so therefore won't be able to code this option.
Artful what model do you have.
