Results 1 to 5 of 5
Thread: R-Line carpet - not sure if the replacement carpet fitted is correct
    Jul 2020
    Hi,
    I am wondering if someone may be able to help?
    I had the unfortunate experience of needing to have all my carpets replaced in my 2018 R-Line Tiguan... the upside was my insurance company was awesome.
    The downside has been the mob that ordered it and fitted it. I have a concern that what was fitted was not the same as the car came with, it doesn't seem as plush and there are strange markings on it
    I have found a 'press out' in front of the passenger seat (best way I can describe it, see image). This is unfortunately starting to press out and I fear I will be left with a gaping hole.
    Can anyone with a 2018 R-line confirm if they have the same? At present I only have my word against the repairer, maybe my memory is wrong and if someone can set me straight and or supply an image of theirs that would be much appreciated.
    Kind Regards
    Drew
    Attached Thumbnails Attached Thumbnails R-Line carpet - not sure if the replacement carpet fitted is correct-img_4613-jpg   R-Line carpet - not sure if the replacement carpet fitted is correct-img_4617-jpg
    Aug 2017
    Vic
    I just checked my my17 tig r line and I have the same press rectangle thing
    I also think if I push on mine hard enough it may push theough
    its like a provision for wiring, maybe on tigs with electric passenger seat motors or something
    May 2007
    Drew, that is the same on most (if not all) VAG models for the past 20yrs or so.
    That is "punch out" for additional equipment, such as Dynaudio Amplifiers / Bluetooth Modlues (back in the day) etc. etc.
    Nothing to be concerned about, they are all like that. Move on...
    Glad you had a great insurance claim though...
    What actually happened to warrant replacement carpet?
    Do you have a Sunroof?
    Water leak of sorts?
    Jul 2020
    ope126,
    Thanks for the additional info, it is much appreciated.
    Yes I do have a sunroof but it wasn't from that.
    Carrying fuel in the rear and it leaked... a mistake that wont be repeated.
    Do you know if the carpet types are the same between the variants? It does not seem as plush as I remember it - but then again I don't remember the cut out. The car no longer stinks and that is the main thing.
    thanks again
    Jul 2020
    Smarty, thanks for taking the time and checking, it is much appreciated.
    You have helped put my mind at ease - it has been an ordeal.
