Results 1 to 6 of 6
Thread: Power tailgate
    May 2009
    Perth WA
    Power tailgate
    Hi, is there a way to manually close the power tailgate? Say you are carrying a large item sticking out the back?
    Oct 2018
    Melbourne, VIC
    Quote Originally Posted by franjae View Post
    If you're in a SWB; with the car on, sit in the driver's seat and hold the tailgate button up (the one on the driver's door). Let go once it reaches a height you're happy with. Would probably require someone to 'spot' you.
    Otherwise, close the tailgate how you usually would, and once it hits the object, it'll stop, retract back a few inches, then come to rest.
    Oct 2015
    To the literal wording of your post- yes, just push/pull down the tailgate. It won’t damage anything in the system.
    Is that what you mean?
    Pacific Paradise QLD
    Quote Originally Posted by PDMJO View Post
    Only works if the engine is running
    May 2009
    Perth WA
    Quote Originally Posted by Simonr23 View Post
    Ok, so instead of pushing the button, you simply pull the tailgate down like you would in a manual one?
    Oct 2015
    Yes. I’ve done it a couple of times. It’s pretty stiff/resistive- especially for the first 2-3cm of travel. But once it detects manual input, it must react electronically/electrically and the magnetic force of the motor(s) stops.
