Same here, Tiguan 132TSI comfortline with no DAP only has parallel assist parking working , there is definitely no 90 degree functions ;( VW cheating again , on my old Q3 2015 if you press twice parks assist button it change on display from Parallel to 90 Degree and vice versa , VW crippled definitely this function for some reason? I see there is option to activate in VCDS long coding when log to park assist module but when try to code it will not accept out of range functions so restricted error....( I don't know if require special security code those find on net for GOLF MK7 accept but seems does not work , for some reason even hardware is capable is only software coding restricted thing.
- You may not post replies
- You may not edit your posts
Forum Rules
