I don't know if this affects our series 2 Tiguans but I came across a Series 1 Tiguan stuck at a petrol pump. Apparently he had a flat battery and the electric hand brake was jammed on. He could not put it into neutral and release the hand brake to roll it away from the pump. He was stuck there until the NRMA came with a set of jumper leads.
Are we going to have the same trouble if we get a flat battery?
Sent from my SM-G930F using Tapatalk
Ordered: 2017 build date Tiguan 162 TSI Highline with DAP in Tungsten Silver and rear luggage tray. ETA: late April / Early May. I did not have to wait. I took delivery on 11 March 2017.
I have a series 1 - 2015 Tiguan 130TDI and tested the release of electric handbrake and putting car in Neutral by only having ignition + pressing brake pedal and works. Maybe battery didn't have enough juice to perform the job.
Sent from my HTC_PN071 using Tapatalk
MY15 TIGUAN 130TDI R-LINE - Pepper Grey, Panoramic Sunroof
I have the 162TSI with R Line Pack, the infotainment system is certainly a big con in my opinion but hopefully this can be resolved with software updates.
I know that the upcoming iOS 10.3 will have some changes to the Car Play interface, hopefully there are a couple of other improvements
Thanks for sharing! Out of interest, are you using an aftermarket lightning cord or an Apple cord?This may not be correct, however I have heard it may make a difference as Apple gives preference to branded accessories...? Does anyone know if this is true?
Annoying to hear the MBii is poorly executed. This will be my first VW... I am not looking forward to living with the interface... it was already annoying me on the test drive.
Can you receive software updates from the dealer? If so, what are the release cycles?
VW first timer.
2017 Tiguan 162 Highline :: Sunroof :: DAP :: R
*April delivery
I have an iPhone 7 and (pretty sure) I am using a 50cm Apple branded USB-A to Lightning Cable that I got from the Apple Store.
I have heard that the cables can impact it so I might try some other MFi cables I have lying around. The 50cm one is a perfect length though. I also wonder if it can be impacted by when I plug the phone in, as in at what stage of the infotainment's initialisation, and see if that impacts it.
It is extremely annoying, I was hoping it would be a lot more instantaneous so that I can be playing my music from my phone from where I left off when I shut the car down rather than waiting for it to re-connect and start up again. Throw in the change to the rear view camera which interrupts the start up process and it can be close to 5 minutes before I get to hear any music after starting up.
The Apple Car Play setup is actually more annoying at the moment than useful and ideally I would prefer to just stream music rather than plugin, hopefully this changes.
Would be keen to hear of anyone else's experiences.
