Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Oil temperature at normal operating level
    Pacific Paradise QLD
    My oil temp seems to be sitting around the 106-109 level on a 30 Deg day at highway speeds and doesnt drop much below that cruising around town.
    Is it a bit high as I have put a full undertray on and wondered if airflow may be compromised and affecting it.
    Might pull the tray off and see if it makes any difference.
    May 2018
    Brisbane QLD
    This is normal for the factory oil and just in general for these engines. I run Penrite now and don't see anything over 105°
    Sent from my SM-G977B using Tapatalk
    Jan 2019
    Sounds normal Hillbilly.
    Twyat1, out of curiosity are you running 5w30 Enviro+?
    Sent from my Pixel 3 using Tapatalk
    May 2018
    Brisbane QLD
    Quote Originally Posted by Beedub View Post
    Yeah that's the stuff!
    AM running whatevers in it as its only done 3500k Will eventually have Penrite Enviro +but I have 15L of Castrol approved oil on the shelf so will use that first
    Oct 2015
    That temp is fine. I get into the 110-115 range easily- though a Diesel engine, so perhaps different characteristic there?
    Water would be getting a bit high at 105-110, but oil is fine to about 120.
    Quote Originally Posted by Simonr23 View Post
    Water is stable on 90 so I guess things are normal was just a bit curious because of the undertray as the normal one is very short and doesnt protect anything and when you have plastic sumps I think its a bit off and done to cut costs
    Adelaide hills, SA
    Plastic components are used to save on weight and emissions as well.
    Sent from my iPhone using Tapatalk Pro
    I realise that but think that having no sump protector in a vehicle that has "offroad" capabilities is a bit short sighted. The factory tray doesnt even protect from a stone thrown up by a front wheel as it doesnt go anywhere near far enough back to protect the sump in anyway at all
    Adelaide hills, SA
    I don’t think that the rock flying of from the front wheels can ever hit the engine sump.
