Results 11 to 20 of 27
Thread: No more stop/start.
    Pacific Paradise QLD
    Quote Originally Posted by masster View Post
    This topic made me register for this forum.
    Here is my opinion. Although in theory, BCM should do a great job, in reality, it doesn't allow the battery to charge more than 50%. Most of the time the battery has 12.2 V in the morning. I tested if there is a parasitic draw and the car sleeps rather quickly to about 5mA consumption overnight.
    I own a Tiguan Mk1, 2015, 1.4 TSI 122hp R-Line, with a Start/Stop function and a button on the centre console to disable it. Most of the time I disable that stupid feature. Several times I had the unpleasant surprise of not being able to start the engine.
    Of course, we don't have the luxury of having clearly displayed on our dashboard the State of Charge (SOC) of the battery, which should be mandatory. Why isn't BCM doing that beats me. It would be more useful than a simple battery red alert indicator.
    Nevertheless, I will disconnect J367 too because I can't risk myself to be stuck in traffic or at home just because the BCM does a poor job. By the way, my Varta 65 Ah battery is special for the start/stop feature and I coded it correctly using VCDS.
    Do you lock your car when not using it. Why you ask
    Well as I understand it if car is unlocked not all of it shuts down and it sits there thinking to itself. "Is he going to start me up. I had better be ready" and so keeps some stuff energized and therefore causes a bit of a battery drain.
    If you LOCK IT it says "Oh good I can go to sleep" and shuts everything down eliminating any battery draw. Rather simplified I know but explains it a bit.
    The BCM allows the battery to charge to 80% to allow for regenerative charging and if you disconnect the plug as above, it charges it up to 100% and doesnt allow any headroom.. Your car your money but I know what I have found to be ok and despite having 2 dashcams also installed car never failed to start in 3 1/2 years and I only drove it on mostly short trips so was harder on the battery.
    hmm.......... your Mk1 Tiggy was built with a PQ46 platform whereas the original vehicle which was the subject matter of this thread (mk2 Tiggy) was built with a MQB platform - very, very different cars!!!
    An important difference between the mk1 and mk2 vehicles was the role of the EMS - in the mk2, the EMS was managed by J533 which is called "Gateway" module by various diagnostic devices and in the mk1, the EMS was controlled by J519 (the BCM).
    Simply because the 2 x vehicles use the same name (EMS), doesn't mean that the EMS has exactly the same function. Almost certainly, the EMS in the later MQB platform car is the next version EMS (and therefore almost certainly, it was more sophisticated)!
    Why do you believe that "it [BCM] doesn't allow the battery to charge more than 50%" ? The position suggests that the Regeneration function of Start Stop (i.e. energy recovery during braking) can recoup up to 50% of the battery capacity. This is NOT technically feasible, regenerative braking simply isn't that efficient- no offense intended!!
    As I said in my first response to OP "With early MQB cars, VW allowed drivers to view the battery State-of-charge (SOC) measurement which invariably showed 80% . This facility was withdrawn in later models because (I suspect) drivers kept complaining to VW" that full battery capacity was not being achieved.
    Note the 80% number - this is an actual SOC measurement on early MQB platform cars. The number is NOT "50%"
    Nevertheless, I will disconnect J367 too because I can't risk myself to get stuck in traffic or at home just because the BCM does a poor job. By the way, my Varta 65 Ah battery is special for the start/stop feature and I coded it correctly using VCDS.
    OK - this is entirely your decision (and wholly your right) - My view is that the short term benefit that you believe results from disconnecting J367 comes with a long-term cost of compromising the longevity of your expensive battery!! But again, your decision!!
    Finally, below is an extract from a post that I wrote on the OBD11 forum regarding J367 - which I call the "Battery Monitor Module" (BMM). Hopefully it will help in your understanding of this matter - ignore reference to mk8, the dialogue is equally applicable to your mk1 Tiggy
    This is a diagram of what's inside the BMM and what information the data-stream provides to the car's EMS - I thieved this picture from a
    MQB platform car -but I expect that it is equally applicable for a MQB-evo vehicle like a mk8 (note the BMM is called J367 in the VW wiring diagrams):
    As I have said, I suspect that the LIN facility in the diagram above is replaced by a pair of CAN wires on a mk8 and I expect that on this 2nd generation version of the BMM, the functions that use the battery information stream is even longer!! However, my assumptions about a mk8 notwithstanding - what's clearly evident from the function list above is that the BMM data-stream is pivotal to a wide range of EMS decisions - extending well beyond the SS facility
    I've argued in other forums that deleting the BMM data-stream from the EMS must affect the performance and longevity of the battery on cars that have SS. These EFB/AGM batteries use more sophisticated manufacturing methods than normal flooded-cell techniques and they require more disciplined charging regimes to maximize performance and battery life.
    Notice the Shunt resistor in my diagram above - this component of the BMM measures EVERY milli-ampere of electrical current that is either drawn-from, or injected-into the battery over the life of the battery. So, together with the Battery information that the hex19 module stores as adaptation channels when the battery is installed into the car, the EMS maintains a complete history of battery capacity and it uses this historic data to adjust the optimal charging profile for maximal battery longevity! When the hex19 module is told that the BMM is not installed (via this tweak) - this entire data-stream is lost to the EMS!!
    Jul 2024
    As per earlier threads for my car (2024 Cupra Leon - MQB Platform), I'm learning sooooooooo much re the current generation cars from those that have had experiences good/bad with mods and what does & doesn't work.
    Specifically for the start/stop disable, I saw in my farcebook feed the other day, this
    Seat Leon - Disable Start-Stop, keep last Drive Mode and more
    – Burteq
    You can get either the Start/Stop only or other features, and I've also seen the Aliexpress versions.
    Here are two sellers and way different prices
    $47 version - https://es.aliexpress.com/item/10050...Cquery_from%3A
    $28 versions - https://es.aliexpress.com/item/10050...Cquery_from%3A
    Any thoughts ?
    Funnily enough, my existing issues mean S/S doesn't work anyway .....
    2024 CUPRA Leon V Tribe Edition
    Quote Originally Posted by Michael_B View Post
    – Burteq
    Any thoughts ?
    Well in most models all of that except for the S/S is adjustable in the MMI menus , unless you have a poverty pack without the necessary hardware So is an unecessary thing.. Also did you read ALL the Ad
    Important Note: This device is for off-road use only. It is not road-legal and cannot be used on public roads. So that alone renders it useless. Dont know about in AUS but they said it
    Aug 2021
    Important Note: This device is for off-road use only. It is not road-legal and cannot be used on public roads. So that alone renders it useless. Don't know about in AUS but they said it
    That's a pretty standard disclaimer. There are a bunch of mods which are technically illegal but are commonplace. Heck, tuning your ECU is illegal unless you get the car engineered with an accompanying emissions test.
    Quote Originally Posted by petemac110 View Post
    Well aware as I did about 36 mods to my Tig but none were performance ( apart from the Audi mod) or suspension mods. Merely pointing it out so if anyone buys it without reading they will be aware. As I said most is able to be done without it . My Kamiq has the ability to do all that. without anything to help it and the Cupra etc are all built on virtually the same platform so should be similar. Also am a bit shy on inserting cables where they may not be the best place to go. If you can adjust the electronic parameters fine but sticking cheat cables in is a bit off in my book
    Jul 2024
    Yep, read the bit re "Off road use only", but that's just a disclaimer to try and save them, but not something that'd work with a good lawyer. Anyways ......
    Hiya hillbilly - I'm with you re prefer to do the tuning via coding/using OBD11, BUT, I've found out the hard way that what works with VW doesn't always work the same with the Cupra, even though it's made by the same mob.
    It's frustrating as hell, and I've tried multiple options to solve my issues and still not easily getting anywhere.
    I could just also turn it off each time I get in the car, but that's not the way I like it ....
    Biggest problem is since they changed things as I said about the camera model and probably other stuff, things have been much harder to do, to the extent I have given up on most stuff. Im probably going to lose my license in a few months due to one eye going very bad so not worrying any more.
    Jul 2024
    ... Im probably going to lose my license in a few months due to one eye going very bad so not worrying any more.
    Bugger, sorry to hear that
    Jul 2024
    – Burteq
    I HATE the fact that some people cant/dont ship worldwide.
    To ship to Aus via UPS is A$193
