![Quote Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
drivesafe
About a month ago, I read where by disconnecting a two wire plug on the Negative ( - ) battery terminal clamp, the STOP/START function no longer works.
I disconnected the plug a month ago and the STOP/START function has not worked since.
I wanted to check that this did not cause any error messages to be generated, and to date, nothing out of the ordinary has happened.
I also needed to monitor the operating voltage of the alternator, as I suspected the operation of the alternators voltage levels may be effected by this mod.
I needed to monitor the charge voltage as I occasionally use a second battery and wanted to see if this was going to be effected.
The operating voltage stays at a steady 13.6v to 13.85v at all times in any operating condition.
Again, this has not caused any adverse charging problems and because the voltage does not drop to 13.0v as it normally would, the charging of both batteries is actually improved.
@drivesafe: Hi. I'm delighted to read of your firm conviction that removing the connector on the Battery Monitor Control Module (it's called "J367" on the wiring diagram) has no adverse ramifications.
As I read your analysis, at the heart of your conviction is the notion that pulling the J367 connector has no impact (other than disabling Start Stop (SS)) because monitoring Start Stop is it's ONLY function
Without intending any offense, alas I don't share your belief - for the following reasons:
Here's a diagram showing how J367 is connected:
![](https://www.vwwatercooled.com.au/forums/images/imported/2020/09/LKWkmuspng1-1.jpg)
As you can see, J367 is a LIN slave to the "Data bus diagnostic Interface" module (this is called "J533") and it happens to share this communications wire with the same wire that the alternator uses to talk to J533.
So, the fact is that J367 does indeed have multiple roles on MQB platform vehicles (like your gen2 Tiggy); it's primary function is to provide a constant stream of real time data about the battery (via the LIN comms line shown above) to the car's Energy Management System (EMS). This data includes (but is not limited to) Battery voltage, Battery temperature (the EMS uses an algorithm for this) and a complete history of electrical current drawn from the battery and injected into the battery over its life cycle. This data stream is used by the EMS to make decisions like:
- If there is sufficient battery capacity to re-start the car if SS switches off the engine
- How much "headroom" there is on the battery for the injection of additional amps from the energy recouperation facility
- how to modulate the alternator charging current over time so as to optimize the longevity of the battery based on the settings that are recorded in J533 about the battery (like manufacture type, rated battery capacity and date of battery installation)
The reason why pulling the connector from J367 is the (supposed) fix for SS is that the EMS has no information about this part of its decision making role, so it thinks the there is insufficient battery capacity to re-start the engine.
And, the reason why it's vitally important NOT to connect the negative battery cable from a jump-start battery, or battery charger directly to the negative battery terminal of the car battery is because it by-passes J367. If J367 is by-passed, it means that the EMS does not measure the amperes being injected into the car battery by the external device - which in turn means that the true history of the battery is lost - which means that the EMS cannot correctly modulate alternator charging current over time to optimize battery longevity.
So, as I have suggested, J367 is part of the car's wider energy management function and removing the data stream is NOT a trivial matter, or a matter that affects just SS.
My suggestion is to replace the connector immediately so that the battery history file on the EMS is not further corrupted. If you want SS disabled, do it properly via a tweak from a diagnostic device, or install/make an auto SS kill switch (I've designed a few which you can find on the Golf mk7 forum)
PS: I also have disabled SS on all my cars - but I would never do this by disconnecting J367. And, disconnecting the cable to J367 does indeed result in an error which is shown on a diagnostic report from VCDS, OBDeleven, VCP, ODIS etc.
