Thanks Hillbilly, I was able to get the manual![]()
Anyways it seems like the bootlid rubber seal is the main source to the leakThere is a gap on the top right had corner where the seal bends. It doesn't seat properly and looks like water leaks and goes into the gap inbetween the body panel.
Water was basically collecting at the bottom where the 'cabin pressure relief flaps / values'. So whenever I became mobile it would spill into the wheel well without wetting the carpet. To prove this was the issue, I poured water where the seal was failing and could clearly see it collecting at the bottom![]()
I applied some clear silicon sealant to the exact spot and did the same test and guess what bingo leak stopped.
So I have to get the dealership to change the seal as the car came with the leak. If they don't then will change the seal myself.
