Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 54
Thread: New map update for VW & Skoda available here
    Pacific Paradise QLD
    Quote Originally Posted by Shifter 12" View Post
    Tried this all morning! Downloaded keka and already had Clean my Drive. Unpacked the .7z file in keka and loaded it on to my 32GB SD card. Cleaned the file which removed “junk” and put the SD card in to my infotainment slot 1. I accessed the system and hit the update. It said looking for update files, then gave me a error message. Tried three time, no joy. I then deleted the SD card and unpacked the file using keka on my desktop. Loaded it on to me SD card and cleaned it. Tried to put in to the infotainment system, more error messages.
    The main file name reads - P90_N60S...3_ROW_NT and within that file are Mib1, Mib2. There are loads of country maps within those two files and presumably you have to load all of them. Or does the system just take what it needs for Australia? Anyway I have lost the will to live! HELP!!!
    Ah the joys of being on the dark side Us normal people end up with
    MIB 1
    MIB 2
    Metaininfo2.txt
    Put it in car and wait about 30 secs and it should find it.
    Take the file to a friend with a real computer and unzip it on that.
    Yes it loads all the maps as it is REST OF WORLD after all and picks the correct one for where the vehicle is located and is the MMI variation installed in the car
    You should not alter the files in nay way as they wont work then.
    I use WIN RAR without problems on a PC
    What is your desktop Is it a Mac also as if its a PC you would use Winzip It works ok I d/loaded the VW one last night and un RAR'd it to an Sd card and its fine
    Apr 2018
    New map on VW site today 28/11 same as above just different file name
    Volkswagen Map & Softwareupdates
    It is Europe. I don't see Australia in the list ?
    Oct 2020
    Hobart, Tasmania
    Thanks Hillbilly, I see Mib1, Mib2 and metainfo2.txt
    I will try again with a PC - my son has a laptop which I can use.
    Thanks again.
    Quote Originally Posted by FastMitch View Post
    Rubbish there are maps for bothDiscover media and Discover pro on there dated 23/11/2020 I DONT USE DISCOVER CARE AND if you do REFRESH IT before looking
    Apr 2018
    I understand the issue. If you select a 2020 Tiguan Australia does not come up under Discover Pro but if you choose a 2019 Tiguan as the vehicle Australia appears for Discover Pro. All good, thanks mate.
    Why did you put 2020 in as yours is earlier than that isnt it
    Nov 2013
    AUS
    I think just select the year your car is built. That’s what in did. You still get the latest maps
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
    Apr 2018
    Question
    Downloaded the latest version P90
    However I can't squeeze it on a 32GB USB by 500 MB and I don't have a larger USB
    As there are many sub directories that have folders for 'other countries', can any files in these other country folders be deleted without affecting the checksum check when you load the USB in the Tiguan ?
    NO NO you cant alter it Has been tried and wont work what are you unzipping it with and what machine A PC or a Crac.
    The properties of the unzipped folder is 29.1 GB and if different you are doing something wrong
    Read the above posts they are the good oil
    Apr 2018
    Technically is bigger than 29.1 GB due to the way file take up set bytes
    Did you manage to fit the P90 on a 32 GB USB ?
