Windoz
Windoz
7-Zip and Fat32
Ok have just finished copying it again to a 32gb SD card. Card had 29.8 free space and map is on it and has left 658mb free space after it finished so no reason why you shouldn't get the same.
used space is 31,171,051,008 bytes
I copied the MIB1 AND MIB2 and Metaininfo2.txt to the SD card
HAVE PUT IT IN CAR AND IT WORKS
Maybe this is your problem
Which is better WinZip or 7zip?
The answer is simple: it's because you can do so much more with WinZip and you can do it faster, better and with ongoing support for even more productivity and convenience features. WinZip vs 7-Zip is no match: WinZip is a more versatile, powerful, and simpler alternative to 7-Zip.
Tried just now with WinRar
Extract with 7Zip and WinRAR both had the same file size result (below)
Before you copy the files to the USB, on your "PC Hard Drive" after you unzip can you select Properties -> Size (xx bytes) and screen shot what is the size in bytes ?
Alright do this Go up to the link at the start of the thread and download that as i am using that and when I go to the VW map it is the size you say.
So download the Skoda one and try it as it is slightly smaller for some reason but works perfectly
I did download direct from the VW site the P90 version, not sure what you are asking ?
For the VW P90 version, I don't need the the zipped file size but the 'unzipped' file size with WinZip 'on the PC hard drive' (as the USB has different file byte allocations) so I can compare the file size difference.
I prefer to stick with the VW version as I don't want an issue that could have the warranty claim denied on the Discovery Pro.
For the VW P88 version, unzipped file size is:
I have been using them for 2years and shows the same info in your MMI as the VW one because it is the same thing with a different file name. Other than that you can buy a 64gb card for less than $20. Cant help more than that
OK 0930 this morning I have unzipped the VW P90 direct to my 32gb SD card It goes on it ok no problems
EG 29.2 GB 31,371,034,624 bytes on card
658MB free on card
So dont know why you cant get it to work
This is what it says on the MMI after I loaded the SKODA version Exactly the same as what the VW vers says
I have given up. Could do it on a PC as no Win Zip or RAR. My car has a recall for the sunroof in early January so I will get VW to do it for me.
