Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
Thread: New Active Info Display
  1. #21
    Can you upgrade to this newer AID with a software/firmware upgrade?
    Sent from my SM-G928I using Tapatalk
  2. #22
    Aug 2018
    No, I wouldn't think so.
    It's a different designed housing.
    Active Info Display | Volkswagen Newsroom
    2018 Allspace 162TSI R Line
  3. #23
    Feb 2019
    Perth, WA
    I'm kind of hoping my Tig will be the older generation. Not a fan of those physical fuel/engine temperature indicators on the sides.
  4. #24
    Jun 2013
    Qld
    I actually prefer the old one.
    Maybe in real life they will look better.
    Sent from my SM-G965F using Tapatalk
  5. #25
    Dec 2010
    Helensburgh
    The new one is customisable in far more ways than the old one and the definition is way better. I did not realise the side gauges were physical as the map can be made full screen so I thought they would change to allow for that.
  6. #26
    Apr 2018
    Active Info Display (Polo, T-Roc)
    The Polo and T-Roc are the first Volkswagen models to offer the new-generation Active Info Display as optional equipment. The Volkswagen interface designers have consistently continued the development of the Active Info Display (11.7-inch screen diagonal) and the high-grade graphics system (133 dpi /resolution 1,280 x 480 pixels) and have taken the range of functions to the next level. The screen is slightly smaller than on the first generation and therefore offers better graphic performance, higher pixel density, greater brightness and contrast, more intensive colors and fewer conventional control lamps. Using a view button on the multi-function steering wheel, the driver can also switch quickly and easily between the three basic layouts.
    DPI Calculator / PPI Calculator
    Display size: 10.96" × 4.11" = 45in² (27.83cm × 10.43cm = 290.35cm²) at 116.84 PPI, 0.2174mm dot pitch, 13652 PPI²
    Active Info Display (Golf, Tiguan, Passat, Arteon)
    All the instruments are realized virtually using software on a 12.3-inch Active Info Display. The resolution of 1,440 x 540 pixels allows all details to be presented in an extremely precise and elegant way. You can use five different information profiles to change the type of information displayed and the graphics in certain areas. Drivers can choose between the profiles Classic, Consumption & Range, Efficiency, Driver Assistance and Navigation. The Navigation profile shows a good example of the interactive structure of the Active Info Display. If this profile is selected, the speedometer and rev counter move to the edges of the screen to provide space for the navigation map in the centre. If necessary, information on driving, navigation and assistance functions can be integrated in the graphic areas of the rev counter and speedometer. Data such as telephone contact photos or CD covers can also be presented on the Active Info Display.
    Display size: 11.52" × 4.32" = 49.74in² (29.25cm × 10.97cm = 320.9cm²) at 125.03 PPI, 0.2031mm dot pitch, 15634 PPI²
    "The screen is slightly smaller than on the first generation and therefore offers better graphic performance, higher pixel density"
    Not sure how VW can make this statement as by my calculations the older AID has as greater PPI
  7. #27
    Dec 2010
    Helensburgh
    Never let facts get in the way of a good story. By that it seems the fuel and temp gauges are not physical.
  8. #28
    Aug 2018
    I think I would prefer the newer one if it's more customisable.
    In the current version that I have, there's a couple of combinations that would be perfect but are in two different views, eg speed and distance to empty in the centre if the guages. Otherwise I have to adjust whenever I use the sat nav
  9. #29
    Oct 2015
    I find it odd that the old one has me see the fuel capacity three times on the one screen. 1. Actual fuel gauge, 2. the blue line around the speedo and 3. the distance to empty inside the speedo.
  10. #30
    Apr 2018
    Quote Originally Posted by Simonr23 View Post
    Is the new version better ?
