Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 47
Thread: New Active Info Display
    Jan 2019
    Does the new AID feature better TPMS?
    I'm annoyed that the manual suggests the analogue cluster shows each tyre's pressure, while the AID just reports on whether pressure is low and highlights all four tyres, leaving you to work out which one it is.
    Jan 2019
    Camden, NSW
    Quote Originally Posted by phonebooth View Post
    That’s really strange, I’m almost certain I read that DRL were a feature of the MY19 Tiguan in the specification sheet. Are there no settings in your head unit to enable/disable without coding?
    I didn't mean DRL, so many features, i'm saying the wrong things. I meant DLA, the Adaptive high beams, thought they were coming on the spec sheet. There are no options for this feature that I saw.
    It does have daytime running lights.
    Oct 2015
    Quote Originally Posted by Beedub View Post
    Without going too far off topic (sorry) there are at least 2 tpms used by vw.
    1. Sensors in each wheel stem that measure pressure.
    2. A system that uses the abs sensors to detect change in wheel speed and assume it’s a deflated tyre(likely correct, but not actually tpms)
    The Tiguans we get in Aus are 2.
    Jan 2019
    Quote Originally Posted by Simonr23 View Post
    Bugger. Thanks for the clarification.
    It was only because I had an issue last night and found all 4 tyres were all over the shop, and the manual referred to TPMS and the sensors.
    Anyway, back on topic
    Sep 2011
    Melbourne, Victoria
    Photos of this new display???
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
    Dec 2010
    Helensburgh
    It is the same as the TROC
    Jun 2013
    Qld
    Here you go.
    Sent from my SM-G965F using Tapatalk
    Sep 2017
    Quote Originally Posted by jeromeo View Post
    Here you go.
    those are both the "old" AID
    MY09 MKV Golf R32 | Black Pearl | Recaros | Sunroof | RNS510 | Purchased Feb '10 | Sold Jul '17
    MY19 MKII Tiguan Highline 162TSI | Indium Grey | S&V | Pano Roof | R-Line | Purchased Nov '18
    Jun 2013
    Qld
    Quote Originally Posted by daz32 View Post
    2018.... didn't know it will be different.
    Feb 2019
    Perth, WA
    My Rline which I havent got yet has DRL's and was a 22Nov build so am curious to know if it has the new AID How does one tell one against the other
    Easiest way to tell is the old AID has physical "lights" for the warnings (check engine etc) at the top.
    This is the new AID:
    New Active Info Display-db2017au01138_full-jpg
