Does the new AID feature better TPMS?
I'm annoyed that the manual suggests the analogue cluster shows each tyre's pressure, while the AID just reports on whether pressure is low and highlights all four tyres, leaving you to work out which one it is.
Without going too far off topic (sorry) there are at least 2 tpms used by vw.
1. Sensors in each wheel stem that measure pressure.
2. A system that uses the abs sensors to detect change in wheel speed and assume it’s a deflated tyre(likely correct, but not actually tpms)
The Tiguans we get in Aus are 2.
Photos of this new display???
Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
It is the same as the TROC
Here you go.
Sent from my SM-G965F using Tapatalk
