Originally Posted by
tigger73
Yes the cheaper systems on the market tend to be optical/camera based systems. This is what is in the Subaru Eyesight system - you'll see the cameras up near the rear view mirror.
VW and other European/premium vehicle manufacturers use a radar system. This will work even when you can't see (like in fog/heavy rain/at night/etc).
Radar systems are generally more expensive than optical systems, however in climates where there is a lot of fog/bad weather these are generally better than optical systems. The sensors can still get fouled by snow etc, however the optical systems will be disabled when vision is poor which is kind of when you need them most.
The radar system probably won't work very well with big balloons. The optical systems will see these as solid objects.
