Results 1 to 7 of 7
Thread: MY19 Tiguan - Golf GTi Mk7 Springs
    Jul 2022
    Adelaide, South Australia
    Hi, I was wanting to clarify, is it just the Golf GTi R Mk7 springs that will fit the Tiguan (and lower slightly), or will the Golf GTi Mk7 (standard) springs also do the job?
    Aug 2017
    Vic
    While they may fit given same MQB platform I would have thought that they would have different compression rates. The tig would also be a heavier car for the spring rate too
    Jul 2022
    Good point - thanks for the quick response..
    Aug 2017
    Vic
    I think there was a thread about use of golf coilovers in the Tig a couple years back. Think they were available for the golf but not the tig. Could be a different story now as the new Tig has been out for 6 years now.
    Yes they fit.
    I have mk7 Golf R springs in mine and it is fine.
    I do have EMD Reverse Rake pads in the rear to make it a little higher as I do the occasional family trip loaded up.
    Lots of talk about the spring rate, but I don't notice any issues. That being said, I don't have anything else to compare with
    2019 Tiguan R-Line - IS38 Turbo - Spectuned - X-Force Downpipe - RS7 Spark Plugs - CTS Inlet Elbow - ECS Inlet Pipe - K&N Panel Filter - Golf R Muffler - APR Exhaust Controller - Superpro Rear Swaybar - Digital Dash Retrofitted - 034 Dogbone Mount - DBA T3 Rotors & Pads - Golf R Springs
    Jul 2022
    I wonder if there’s a difference between Golf GTI and the ”R” springs…..
    Pacific Paradise QLD
    Quote Originally Posted by pmencel View Post
    Easiest way to find out would be to check the part numbers wouldnt it
