i have the same issue with my Tiguan's rear suspension . Im taking it to VW service again this Wednesday.
I've got my car back today.
Issue I had:
- squeaking noise from suspension, when going over speedbumps at low speed.
- rocking the car by hand/bouncing up down stationary car would cause suspension to squeak.
took it to VW service, they re-lubricated suspension bushings, re-tension bolts on the suspension system.
checked all OK.
Squeak noise while driving is now gone.
While stationery however, the car would still squeak if rocked by hand (or bouncing up/down like OP).
Squeak only happens when the handbrake is engaged. No squeak with handbrake off.
VW technician shows me other Tiguan R-Line making similar noise/behaviour while stationery.
Mines booked for the 14th!
2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
Mine has been serviced as well.
Removed lower control arm bushes
Greased with VW lubricant
Refitted
Noise gone
Sent from my iPhone using Tapatalk Pro
So got my car back from VW.
My difference is huge. Not only is moaning from the struts gone, but the car is 1000% more stiff now. Potholes absorb like golf did. The DSG is so much quieter and a lot less chattery.. almost quiet and the biggest one I noticed straight away: when the stop start kicks in, the car doesn’t jolt to life anymore, it’s just.. quiet. Very happy with the result on my car. It even feels a bit quicker cause the power feels more direct and firm somehow. They must have tightened the engine mounts as well or something the difference is quite pronounced.
So what did you book it in for...just the squeaky suspension or noisy DSG and stop/start as well?
2018 Allspace 162TSI R Line
Must be psychosomatic then rexman. It’s just not possible for a bushing/ball joint to effect so many negative traits.
It’s still good that it feels better though!
