Results 1 to 10 of 12
Thread: Cheap Tiguan (compatible) wheels
Simonr23 Cheap Tiguan (compatible)... 21-01-2019, 03:26 PM
Simonr23 Will mk1 Tiguan 16’s fit?... 21-01-2019, 03:30 PM
DougGlover That's what I did. ... 22-01-2019, 01:06 PM
tigger73 Not sure but I have heard... 21-01-2019, 10:46 PM
Foxpuppet Cheap Tiguan (compatible)... 22-01-2019, 06:41 PM
Simonr23 i ended up buying some wheels... 22-01-2019, 09:20 PM
Foxpuppet What tyres and size did you... 23-01-2019, 05:10 AM
tigger73 Nice! Tyres look the... 22-01-2019, 09:37 PM
tigger73 Just dug up Dougs pics (for... 22-01-2019, 09:41 PM
Simonr23 17” rims, 225/65 pirelli... 23-01-2019, 06:53 AM
tigger73 I suspect it will depend on... 23-01-2019, 07:39 AM
Foxpuppet Cheap Tiguan (compatible)... 23-01-2019, 07:57 PM
    Oct 2015
    I’d like a cheap set of wheels and tyres for basic off-road driving.
    I’m hoping that there will be other vw vehicles that use the same stud and offset numbers as the current Tiguan/allspace, so I can buy a second hand set of 16’s to put tyres on.
    Please tell me I’m correct. Or feel free to recommend a cheap supplier of wheels that are suited.
    Cheers.
    Oct 2015
    Will mk1 Tiguan 16’s fit? Found a cheap set online.
    Aug 2018
    Adelaide Hills
    Quote Originally Posted by Simonr23 View Post
    That's what I did.
    Replaced rubber with some A/T tyres (225/70R16) - great stuff!
    Not sure but I have heard that 16's won't clear your front brakes (you'd need to test fit to be sure).
    Also tyres from a mk1 Tig will be wrong size so you'll need to swap these off for something the correct profile (to keep speedo accurate).
    Jun 2011
    I’ve got a cheap set of 16” 5x112 CSA Essen wheels that have a 215/65r16 Yokohama GO15 all terrains. They fit my Passat Alltrack quite well with no rubbing of note. Tiguan wheel arch is bigger than a Passat isn’t it?
    Oct 2015
    i ended up buying some wheels and tyres from bobjane. was just easier. i dont really like the rims, but theyre function over form.
    Cheap Tiguan (compatible) wheels-img_8901-jpg
    Jun 2011
    What tyres and size did you get?
    Nice! Tyres look the business!!!
    Just dug up Dougs pics (for reference) - some Gen1 16" wheels:
    Oct 2015
    17” rims, 225/65 pirelli scorpion all-terrain plus tyres.
    The brake calipers must be so close on the 16’s. I only have about 10mm clearance with these particular wheels.
