Page 92 of 96 FirstFirst ... 42829091929394 ... LastLast
Results 911 to 920 of 953
Thread: MY17/MQB Platform Tiguan Discussion Thread
  1. #911
    Oct 2016
    Quote Originally Posted by Gladbach View Post
    One thing that bugs me a little about the Tiguan (well, will bug me when I get it) is that is has that hatch back style hard luggage compartment cover instead of a retractable cover that most SUVs and wagons get these days. Has anyone else been a bit put off by it? Retractable ones make so much more sense as you don't have that annoying hard panel to store somewhere when you're loading up the boot.
    I would have even been prepared to buy a retractable one as an accessory.
    Hadn't noticed this on the first inspection. That really is a cheap arsed solution befitting a Hyundai.
  2. #912
    Jun 2012
    Dee Why, NSW
    Quote Originally Posted by IsDon View Post
    The Tucson has a retractable screen, so even they got it right. I will say one thing though, after driving my in-laws wagon quite a bit which has the retractable screen, it can be a little annoying to always pull it back over, so at least with the tiguan you don't have to do that. But still, I'd rather the screen.
    2017 Tiguan 162TSI Highline/R-Line
    2017 Audi S3
  3. #913
    Oct 2016
    Artarmon, NSW
    IsDon has a very valid point. Where do you put the full size flat tyre when you have the spacesaver holding one end of the car up?
    Maybe we should invent a clip-on space saver tyre. You don't remove the flat tyre, you simply clip-on the space saver. That way you solve the boot space problem.
    WOW! I think I might be onto something
    Ordered: 2017 build date Tiguan 162 TSI Highline with DAP in Tungsten Silver and rear luggage tray. ETA: late April / Early May. I did not have to wait. I took delivery on 11 March 2017.
  4. #914
    Sep 2016
    Bendigo, Victoria
    Does anyone think the highline version would look ok with comfortline 17 inch rims / tyres? It looks like this is my only option if I want a highline that can takes chains - after inspecting a highline today there is zero hope of fitting chains to the standard highline 234/55R18 tyres
  5. #915
    May 2010
    Quote Originally Posted by NjB View Post
    You can fit whatever size rims you want. Just make sure it clears the brakes. Adjust tires and you are away.
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
  6. #916
    Nov 2016
    Personally I like to design of the 17" rims on the comfortline (which is what I have ordered). If these can take snow chains then this is probably the main advantage of this model.
    I have come from a vehicle with low profiles and I am actually looking forward to having a car with a bit more of a tyre profile for a change.
  7. #917
    Sep 2016
    Bendigo, Victoria
    Comfortline can take 12mm snow chains. Highline not a hope in hell. That is the issue for me as I have an opening for a 162TSI highline with Jan delivery but I want a car I can take to the snow in Victoria which means snow chains are a must. Really peeved.
    After comparing both tyre types last night the Highline has noticeably more sporty looking tread on its Continental tyres whereas the Comforline has more normal car like tread on its Michelin tyres.
  8. #918
    Oct 2016
    If your issue is the ridiculous requirements for diamond pattern snow chains at one Victorian snowfield then do what I do. Take your business elsewhere.
    There are a multitude of snow chains that will fit all sized wheels fitted to just about any vehicle. These snow chains are perfectly acceptable on any snowfield on the planet except one under the control of a small minded nanny state bureaucracy that is Victoria.
    Drive North. Visit the NSW snowfields in the vehicle of you choice, with the snow chains that fit, and leave the Victorian snowfields for good. If more people left, they might just revisit their silly rules and change them to be in line with the rest of planet Earth.
  9. #919
    Oct 2016
    Artarmon, NSW
    I think Thule make snow chains that will fit the highline tyres.
    Sent from my SM-G930F using Tapatalk
  10. #920
    Sep 2016
    Bendigo, Victoria
    Yeah there is the Thule K-Summit spider chains but I spoke to a retailer of them and he said they are not effective with summer tyres as they slip off the tread easily. Only diamond chains have any effectiveness, however limited, with summer tyres and the Highline can't take 12mm chains safely with only a couple of mm clearance.
    I am fine with giving Hotham the flick as I am only interested in Buller and Falls anyway but I want to get there safely on bad days!
