Some of the differences between the Allspace are surprising... even the bonnets are different.
Yes I just did it temporarily as the dealer wanted to see what it looked like and my battery drill was flat Read the insructions ONE SCREW ONLY There is the one screw and 5 plastic plugs which you need to drill 8mm (No other size will do) 4 in the fronts and 1 underneath Dont push it in more than necessary as its into soft stuff. Make sure the liitle lip at top inner is up against the black mudguard roll as putting the screw in tight with that in right place locates it to drill the other holes
Have also just finished putting 3m clear protective film on all the door sills and the alloy strips with the light in them so nothing gets scratched.
Also did the rear bumper down to the garnish strip and rolled it over the top and will put a fibreglass protector on there as piece i had wasnt wide enough to go right in to boot door seal
Here is the link to a fully installed mudflap 20190414_101126[1].jpg - Google Drive
You of course cant see the one underneath and if you are clever you can install them without removing the wheel Just need a 90deg drill converter LOL Lots of fun
Hi guys,
Received a 2019 Tiguan the other day and I love it, but there's one tiny thing I can't work out. How do you display the time on the dashboard?I've gone through all the settings and combinations as far as I can tell, and the best I can do is get the date to display on the dash (which seems to show up in the top right if you choose the media option in the right hand display section). I can't see an option to show the time on the dash or on the center screen....
