Page 69 of 89 FirstFirst ... 1959676869707179 ... LastLast
Results 681 to 690 of 884
Thread: My Tiguan has arrived and this is my experience so far
  1. #681
    Quote Originally Posted by iDiesel View Post
    Is there any stickers that you can get to put on the puddle lamps on a highline so that it can project the VW logo, Wolfsburg logo or Rline logo?
    Everything I see on eBay is for the door lights
    I haven’t seen anything for the puddle lamps. I’m not sure how well it would work even if they were available.
    One other observation is that this has to be one of the most dribbly cars I’ve ever owned.
    After I wash it I’ll dry it off but then I inevitably end up coming out later to water runs from the mirrors or boot.
    Anyone else had similar experience?
    Jun 2017
    North Sydney, NSW
    @Tigger73 I always take it for a blast around the block to shake the water out and then a final wipe of all those exact spots you show.
    This also dries the brake pads and rotors as I had the handbrake bind up the day after washing a couple of times.
  4. #684
    Jun 2017
    North Sydney, NSW
    Yeah if I sit sideways it's not so bad either
    It's only really noticeable when you're setting up your driving position. If you put both hands at the top of the wheel it's fairly obvious that your shoulders are slightly twisted. Though it hasn't caused me any problems/issues on long drives.
    It's more a psychological issue...
    Go and test drive another one and see if it is same or different. If the seat is askew it’s gonna drive you bananas for just knowing. Maybe a safety and ergonomic issue too.
    Try this approach with the dealer https://youtu.be/BlUM887Cuus
  5. #685
    Apr 2013
    Quote Originally Posted by spacemannz View Post
    The exact same thing happened to my Golf a few times. Do you reckon the handbrake binding up due to surface rust is a VW-specific thing?
    The Golf dribbles a bit too. Wing mirrors and near the boot sill in particular
  6. #686
    Jun 2017
    North Sydney, NSW
    Quote Originally Posted by Jimi View Post
    Nah, I’ve had it happen to my previous Mondeo. It didn’t have electric handbrake, but did have the euro spec brake pads and soft alloy rotors.
  7. #687
    I'll try running it around the block if nothing else than to remove excess water. I've had the hand brake bind up on the Tig before. Makes an awful clunk when it disengages.
    I suspect it'll still dribble - I even wipe down inside the boot sill but it still manages to run out. I think I'll just have to keep a micro-fibre cloth in the car to fix up the dribbles. Just it leaves water marks if you don't get it straight away and they can be hard to get off.
    Well took it around the block and then wiped down. Went to the shops to pick up tea and I’ve got splatters down each front door:
    I think this is going to be one of these ongoing things...
    Jun 2017
    North Sydney, NSW
    Oh well, time to lick a hanky and wipe the water spots off. Looks like a mirror finish otherwise 👍
    Perhaps the water will come off better when you have stage 2?
  10. #690
    Grab a mini blower skin made by whichever brand cordless power tool batteries you have at home. Use it to blow the water out of all the drippy bits before you dry.
