Page 67 of 89 FirstFirst ... 1757656667686977 ... LastLast
Results 661 to 670 of 884
Thread: My Tiguan has arrived and this is my experience so far
  1. #661
    Quote Originally Posted by FastMitch View Post
    The nag screen on the head unit that comes on every time you drive and won't go away until you clear it.
    Can a VCDS change fix this ?
    Yes this can be disabled via VCDS and I have done this today
    Adaptive Cruise works well, however it's default setting is 3 bars and I find in city traffic that's just too far
    I've found this is adjustable in the Car menu settings under Driver Assistance. You can set it to either remember the last distance or default distance you want each time you start.
    Quote Originally Posted by ArdiL View Post
    You can set this in the settings as last set parameter or something like that and it will always start as you left it, no need to adjust every time.
    Thanks ArdiL, I'll be setting this to minimum setting as it's easy to increase it but painful if you want to reduce it as you have to go all the way around...
    Quote Originally Posted by htran View Post
    Many of the annoying things can be deactivated using obd11
    Stop start, startup nag, acc distance default -> remember last setting
    On mine I also had it remember auto highbeam setting.
    The only thing I couldn’t get the car to remember sports and eco gear modes.
    Yes I have VCDS and have turned off stop/start, nag screen and enabled needle sweep on start-up. I hadn't found the setting for ACC default distance, however others have said you can set this up through the car settings screen so I'll give that a go in the morning.
    In terms of sports and eco modes I thought that was under your driver profile... or am I not understanding what you're trying to save.
    Apr 2011
    Perth, WA
    The car will remember sports and eco mode for acc but it won’t remember eco and sports for your gearbox unfortunately. So if you want to be environmentally friendly and you have to select eco everyone drive. It’s not so bad with sports as that’s just pulling the gear lever back.
  5. #665
    I've fixed all your issues Tigger73 with OBD11, I've also set the Haldex to quiet as well but haven't had the chance to properly test it.
    Only thing that is annoying is the slight clunk from the front RHS and now my LHS door has developed a rattle. Might as well replace the speakers once the trim comes off lol.
  6. #666
    Quote Originally Posted by Dose Pipe Sutututu View Post
    Yes all problems fixed with Vagcom except I haven’t changed any settings on the Haldex yet.
    I really wanted to live with the stock car for a bit before going and making any changes. Now it’s a new and improved Tig My Tiguan has arrived and this is my experience so far
    haha I know that feeling
    If anyone is interested, disabling "Starting Vibration Reduction" allows more wheelslip when using launch control
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
  8. #668
    Jun 2018
    any new Wolfsburg owners wanting to share their experiences so far?
    Tiguan Highline 162TSI | White | R-Line | S&V | Sunroof | MY19 (
  9. #669
    Quote Originally Posted by jolv View Post
    It’s identical mechanically to the R-line except for HUD and audio system.
    Of course the external colours are a personal preference thing.
    The first Wolfsburg models were only delivered a couple of weeks back so still early days.
    One other thing I’ve noticed is that the steering wheel appears to be slightly offset (right) in relation to the driving position.
    Whether this is intentional or a requirement for airbags / passenger protection / crash rating.
