Results 1 to 10 of 884
Thread: My Tiguan has arrived and this is my experience so far
    Dec 2017
    They stand out a lot when you open the hatch, Best to forget about it and not look at them.
    Jul 2017
    Queensland
    Can anyone advise the cosmetic differences between MY17 and MY18? Also, anyone with MY18s what was your 'build' date and are your plates listed as '2018' ones when you do a registration lookup?
    Think I'm being shafted on my order...
    Dec 2017
    Quote Originally Posted by atagnat View Post
    I was told by my dealer the only difference between the 17 and 18 was the glass finish on the infotainment unit. There are other reports though that there are also now usb ports in the back seat?
    Jul 2010
    Mine is a late Oct 17 build MY18, complied 01/18. Shows up in rego search as a 2017.
    Cosmetic differences I'm not 100% sure, but mine has the different infotainment glass as someone else mentioned, two USB ports in the front and a USB port in addition to the 12V charging port under the climate control at rear of the centre console for the back seats.
    If you want me to look at anything in particular let me know and I'll take some pics.
    Dec 2017
    SA
    Quote Originally Posted by Dan_3MPS View Post
    Just a qu, where are the USB ports at the front? I have one with th 12V, mine is same date, Adventure
    Jul 2010
    Quote Originally Posted by Jackson22 View Post
    Might be hard to see, but just in there
    Sent from my SM-G955F using Tapatalk
    Congratulations on the new car Dan. My local dealer doesn’t have a sportline yet so I haven’t driven one. It looks like a great package but my one reservation centres around the ride comfort with the 20” wheels. I know it has adaptive chassis control which will help. What's your view on the ride comfort so far? Thanks
    Jul 2010
    Quote Originally Posted by Brycem View Post
    I came out of a GTI with 18s so my reference point maybe different to yours
    The comfort suspension setting works well for low speed stuff around town, but is too soft above 80.
    Normal mode works well most of the time, I'm trying an individual mode out now where I've set a mix of sport and normal settings and I like it.
    Having the tyre pressures correct helps too, when I picked the car up they were all over the place which made the ride worse than it needed to be.
    Sportline is a great package, definitely a sweet spot and you should be able to drive one away for under $50k if you don't want a sunroof.
    Dec 2017
    I'd like to know other people's experience when using the different drive modes.
    I often run the car in Eco mode, but every time I turn the engine off, the drive mode will default back to normal Drive when I start the car again. But all the other settings remain in Eco mode.
    Same thing happens if I am in sport mode. The drive mode will revert back to D after a restart while steering/suspension remain in Sport.
    Does the same thing happen to everyone else? Is annoying having to choose your mode again every trip.
    I have a 162tsi R-Line.
    Sep 2012
    Have you tried saving your preferences to your car profile and the key? It should then remember all settings including seat, radio etc.
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
