Page 39 of 89 FirstFirst ... 29373839404149 ... LastLast
Results 381 to 390 of 884
Thread: My Tiguan has arrived and this is my experience so far
  1. #381
    Quote Originally Posted by Schland77 View Post
    Does anyone who has received their Tig know how to activate automatic high beam control? I was pretty sure it's available in OZ.
    In my car, I need to just turn them on. On AID there is an icon which show it is working.
    Also, does your car automatically stop when detecting an obstacle while reversing? I believe it is maneuver breaking- can't seem to get it to work
    Yes, and it was unexpected for me when car was stopped - behing me I had only grass. But my friend had situation when he was reversing, and behind him car started moving forward - it worked too.
  2. #382
    Aug 2016
    Auckland, NZ
    Does anyone who has received their Tig know how to activate automatic high beam control? I was pretty sure it's available in OZ. Also, does your car automatically stop when detecting an obstacle while reversing? I believe it is maneuver breaking- can't seem to get it to work
    I don't think the cars in AU or NZ have the Automatic High Beam option enabled but can be turned on by coding (see the first post here regarding Light Assist: A guide to enable EU specific features for AU Spec Tiguans). I know I don't have this option under the Car Setup menu but planning to enable it once I can confirm the coding changes required.
    With regards to the automatic braking when reversing I can confirm it definitely works on my car. To get in to my carport I have to reverse in on an odd angle and get as close as possible to the opening on the right hand side of the car. Normally I just get a lot of beeping but 2 occasions now the car has decided that I was getting a bit too close and slammed on the brakes for me. The first time it gave me quite a fright but now I know what it is it may seem a little annoying since I know I wasn't actually going to hit the wall but I can see how it could save my ass when backing out of a car park and someone impatiently drives past.
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
  3. #383
    Nov 2016
    Quote Originally Posted by bestyjny View Post
    Thanks, does it show the blue high beam indicator in the AID with an A in it?
    I will try to reverse into something (something that doesn't damage the car) and see if it stops
  4. #384
    Nov 2016
    Quote Originally Posted by NZ_GolfR View Post
    Thanks, I will try the reversing again. In regards to the high beam assist I thought I read that somewhere- I will see if I can find it -
  5. #385
    Sep 2016
    Balgowlah, NSW
    Turn the dial on the right near the driver's door to 'Auto' and the headlights will adjust based on light levels and traffic. Works really well.
  6. #386
    Position "zero"
    Push once left "wand" (don't know how to call it in English) outside of you, and white beam indicator will show near shift indicator:
    Push it again, and it will switch permanently to high beam, and white indicator will gone, but blue one appear:
    Doing this again and again you can switch modes. If you pull it to you, it will shut high beam off - but only from "blue" mode.
  7. #387
    Nov 2016
    Position "zero"
    I tried that but it seems that is yet another feature not enabled in Australia- thanks for your effort
  8. #388
    Nov 2016
    Quote Originally Posted by Frogasaursas View Post
    That is right but it doesn't switch automatically between high and low beam
  9. #389
    Not a problem. I spend almost whole day yesterday in my car playing with VCDS.
    Like I said in one of the threads, if anyone curious about something from EU configuration, just ask
  10. #390
    Does anyone know how to store the boot divider in the spare wheel area? The thing just wouldn't fit there unlike what the instruction said.
    I dont want to use it. Any video guide for this?
    Thank you
