I am trying to get tyre pressure and the traffic sign detection displayed on active info display. Anyone ??, please.
Found it. This one: http://www.motoring.com.au/volkswage...review-105631/
"The traffic sign recognition in the Tiguans sat-nav system was occasionally fooled by advisory speed limit signs, on occasion posting a 45 or 35 rather than the 60, 80 or 100 speed limit zones that actually applied. On one occasion we noted that the system readjusted swiftly after the car was past the road sign in question."
I can't find any other reference to sign recognition anywhere else. I find that paragraph a bit confusing too. Sign recognition is done via a camera not via the sat-nav. Perhaps the reviewer got muddled up with speed limit info contained in the sat-nav maps, rather than by a camera that was reading speed signs by the side of the road.
Sign recognition is done by a camera. The same camera used for lane assist. No lane assist then it's not possible. If it's not activated by default or a driver setting then it can be activated with VCDS I believe.
Tyre pressure monitoring isn't displayed as the system doesn't actually monitor the pressure in the tyre per se. The system works through the ABS sensor on each wheel. When you first get your new car, and whenever you change tyres or change tyre pressures you must initialise the system for it to work correctly. Once it has those "pressures" stored it then very accurately keeps track of the rotational speed of each wheel. A deflated tyre will obviously rotate faster than the system expects it should for a given speed which the TPMS will sense. This will then set off a caution for a deflated tyre and tell you which wheel is affected.
