So yesterday I was the unfortunate victim of a nail in the right rear tyre, took it to tyreright and the bloke (and I for that matter) didn't realise the tyre was a "conti-seal" tyre. I've never owned a car that had this type of tyre before. But after he opened it up, it was full of Sticky tar like matter inside, so he had to put the rim back on and all he had to do was pump the tyre up again and pull the nail out, within 2 seconds the hole was filled up and I was off driving again. Like I said, ive never had this type of tyre before, but good to know that I don't have to take it to the tyre shop to have it patched up. Thought I'd let everyone know. FYI this is on the 20inch Suzuka rims.
Sure guys. I understand, that you want to feel pain every time when you use your boot outside or your garage, because you set "open height limit" to use it in garage?
Check how boot door is build (it's form/shape) and try to program it to open it highest part safety to 2-2,2m height Good luck with using it comfortable. Of course, in most use cases it will be OK. And remember that people memory is short, and if once you reset this it will hurt.
In my case (2.0m height garage with outside-open doors), I used styrofoam and glued it to my garage ceiling in place where boot door can be damaged. Also I didn't ordered automatic bood door, becase still in other places like underground mall parkings you can forget about problem.
Without distance sensor it is broken feature for me .... awesome for usability and on paper, but still factory broken.
And again, I'm far away from AU. I never was there so maybe your life experience is different than mine.
Did anyone get charged for floor mats? I just realized I got charged $195 for it and as per Australian specs it should be standard on comfortline and highline- I called the dealer about it today and he said that it is standard on European ones but not in OZ- not to sure if I should believe him or not???
