Threaded View
Guest001 Dunno we just followed the... 21-08-2019,
11:21 AM
Simonr23 Yes, as above. Likely... 21-08-2019,
12:31 PM
phonebooth There's also a lot of... 21-08-2019,
05:41 PM
phonebooth Here are the instructions... 21-08-2019,
10:46 PM
Simonr23 Well done on this post. I... 22-08-2019,
07:43 AM
anobody VCP delayed until... 22-08-2019,
06:15 PM
mr gee if there's enough rain to... 26-08-2019,
09:48 AM
phonebooth Hi,
I replied to your PM. ... 26-08-2019,
10:36 PM
Guest001 You have obviously done... 01-09-2019,
06:24 PM
davman I had something similar... 01-09-2019,
08:24 PM
BinChook Not sure if this has been... 01-09-2019,
09:28 PM
Simonr23 Not in my experience. I did... 02-09-2019,
04:04 PM
Guest001 Well thats good to know as... 03-09-2019,
06:37 PM
Simonr23 It can only mask one area,... 03-09-2019,
06:58 PM
Guest001 Traffic Sign Recognition -... 04-09-2019,
09:14 AM
Tob35 Ahh.. I'm not that tech... 04-09-2019,
09:26 AM
phonebooth Hi Hillbilly,
My byte 10... 07-09-2019,
12:29 PM
Guest001 Yeah realize about the... 07-09-2019,
12:44 PM
BinChook Del*.* 07-09-2019,
10:46 PM
d_nunn88 So I gave followed phone... 23-11-2019,
06:09 PM
phonebooth Does it function as intended?... 24-11-2019,
12:52 AM
d_nunn88 Tested it last night and it... 24-11-2019,
11:05 AM
Reihenmotor5 NAR 2019 Tiguan SEL-P R-Line... 26-11-2019,
09:04 AM
Simonr23 I’m not sure if this helps,... 09-05-2020,
12:11 PM
TIG162R Thanks guys, so just to... 09-05-2020,
12:53 PM
Guest001 If you go into long coding... 06-07-2020,
10:56 AM
nibose Moved my post 08-09-2020,
09:59 PM
nibose HI Everyone,
A couple of... 12-06-2021,
08:41 PM
my journey to activating DLA on a MY17 Tiguan
Hi, I want to share my journey to activating DLA on a MY17 Tiguan (Highline).
Some of my observations:
- MY17 Tiguans have Mid LED headlights which are capable of DLA.
- GLW Sliding Light Width Control (Gleitende LeuchtWeitenregelung) and MDF Masked Long Distance Light (Maskiertes Dauerfernlich) are components of DLA.
- GLW was enabled on module 55. DLA is 'enabled' showing no errors.
- I wasn't able to activate MDF. Coding rejected (31).
- After GLW was enabled, the headlights do a different dance. Similar to YouTube but not the same.
I will need to sort out the following:
- Why is the coding for MDF rejected? I think possibly parameter containing MDF data will need to be flashed on module 55 to resolve this.
- How does DLA work with only GLW enabled?
- Does full functionality of DLA require both GLW and MDF to be enabled?
- You may not post replies
- You may not edit your posts
Forum Rules
