Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 86
Thread: my journey to activating DLA on a MY17 Tiguan
  1. #61
    Pacific Paradise QLD
    Quote Originally Posted by d_nunn88 View Post
    So I gave followed phone booths instructions and it has activated perfectly as described. I did note however that when I start my car, it doesn’t do the flick up headlight dance, though there are no errors in my car. So wondering if anyone else has experienced that the headlight dance doesn’t flick up, but DLA is still working?
    Have you got your lights on AUTO and the stalk pushed fully forward
  2. #62
    Nov 2019
    Perth, Western Australia
    Yes, light switch in AUTO and the Headlamp Symbol with the A on it and no faults displayed.
  3. #63
    Feb 2019
    Perth, WA
    Does it function as intended? There are some posts in the Passat forum indicating that certain light modules are 'parameterised' for DLA.
    MY19.5 Tiguan Highline with R-Line & Sound/Vision
  4. #64
    Nov 2019
    Quote Originally Posted by phonebooth View Post
    Tested it last night and it functions perfectly. I might have a play around and see if I can get the presentation mode to work properly. Thanks again Phonebooth for your instructions, such a good feature.
  5. #65
    This is how it should look It takes a few moments Hit download and wait a bit
    Light pattern.mp4 - Google Drive
  6. #66
    Oct 2019
    Independence, MO
    Mine works on the Arteon, it just doesn't have that start up sequence.
  7. #67
    Quote Originally Posted by SdvolksArteon View Post
    Some Arteons have predictive lighting as well Does yours????
  8. #68
    Oct 2019
    Independence, MO
    Well, it didn't come with it enabled. It's just sporadic when I do enabled it. It might not like the North American maps?
  9. #69
    Nov 2019
    North America
    NAR 2019 Tiguan SEL-P R-Line here, and starting to think DLA may be possible with progress being made with the NAR Arteon. Looking at this and thinking of the economics, why would VW ask for a separate headlight system when you can turn off in coding.
    Even states DLA capable, but may be off due to specific countries.
    For those with the ROW model, was curious in 4B if the following were checked off and/or if someone can shed light on these features.
    In Byte 11 what does dynamical low beam light enabled do?
    In Byte 12 what does segmented cornering light enabled do?
  10. #70
    Nov 2019
    Ballarat
    Here are the instructions I've sent to other users to get DLA working on a '19 Tiguan Highline. Credit to AS Coding @ www.ascoding.ch as my instructions are based on his/hers but with the required changes for the '19 Highline.
    Sorry it's so long but I've documented each step I took in detail. Here we go...
    Hi Folks, I have a MY20 Polo GTI (Fully Optioned, Oz Market)...
    Apologies in advance for the slightly off-topic post, I did originally post here, but have had no luck as yet.
    I don't suppose anyone knows, how I can check if it has the hw to do dynamic light assist?
    Not just high beam assist (i.e. a high/low auto-switch), but can actually adjust angle of beams.
    I'm not sure if it's enabled by default, but there may be the hardware in place for it.
    I own/use a OBD11v2 & may eventually get VCDS, as this stuff just fascinates me.
    Thank-you!
