I noticed I can leave mine in A mode and light switch in Auto. On a road without street lights at the right speed, the high beam comes on automatically and when traffic or street lamps appear, light reverts to low beam
No it doesn’t. You have to be in auto high-beam mode for the car to work out when to activate/control the high-beams. Same as normal.
Tig 162 R-Line; Audi TT
That is High Beam Assist which is different to DLA
Get in car put headlight switch on auto and start car lights should do a dance like this
Light pattern.mp4 - Google Drive
Yes, mine does that.
wnder what extra coding is needed for DLA
Yours does which?????
Why dont you just follow the explicit instructions Phonebooth posted because they work
If it dances like mine you should have DLA if it just drops from high beam to dip right across you have HBA
DLA splits to leave a car in front in the dark or a car coming toward you also in the dark
UNLESS you have an ALLSPACE which has DLA standard
mie does the same light dance as in your video. I have seen phonebooth's instructions though haven't yet had time to see if I can code it in.
Massive kudos to Phonebooth for that detailed post, perfectly easy to follow and activated on mine. I had tried previously and failed, but your instructions worked. I did have an error about the dynamic cornering lights, but it went away by itself.
MY19.5 Tiguan Highline with R-Line & Sound/Vision
