Page 9 of 9 FirstFirst ... 789
Results 81 to 86 of 86
Thread: my journey to activating DLA on a MY17 Tiguan
  1. #81
    May 2019
    Perth, WA
    A quick question: With DLA, do both low & high beams remain ON at all times? or the high beams only come on when you push the stack and see the high beam icon in white colour with letter "A" in it?
  2. #82
    Pacific Paradise QLD
    Quote Originally Posted by nibose View Post
    They just do what it normally does except they split around other vehicles etc. Have never gone out in front to see what happens. Get someone to stand in front and watch.
  3. #83
    May 2019
    Perth, WA
    Both low and high beams are ON at all times in my car. Both the beams vary according to traffic, external lighting and maps inputs.
    My impression was that the high beam will be OFF but turns ON when you push the stalk.
  4. #84
    Only if you have the stalk pushed forwards though
  5. #85
    May 2019
    Perth, WA
    Mine has both low and high beams ON even when the stalk is not pushed, though the high beams are positioned the same as low beams. Is this normal?
    Pushing the stalk enables the DLA & AFS to operate as expected.
  6. #86
    May 2019
    Perth, WA
    HI Everyone,
    A couple of questions: ON Module A5, byte 19, for bit 0-3, I've currently set to 00 (FLA_additional_high_beam,No additional high beam), My car has LED low & high beam. Should I be selecting: 03 FLA_additional_high_beam, LED?
    my journey to activating DLA on a MY17 Tiguan-img_0023-jpg
    Another Question:
    ON Module A5, byte 13, for bit 1-2, has anyone set it to Steering wheel vibration active? Does it work?
    my journey to activating DLA on a MY17 Tiguan-img_0024-jpg
    Also, should bit 0 be ticked for TSR?
    Cheers!
