If anyone wants to code a 17 Tiguan in Sydney cause they are just great guys just let Me know. Because I have no idea wtf you guys are talking about.
Gents. Are you certain that turning off Byte 10, Bit 3 under 4B, for Highway light is what removed the Country light and added the Motorway light? I ask, because, I've setup DLA on my Arteon and currently have the Country Light setting. I absolutely hate it. Most of my driving at night is done on dark highways with almost no traffic and I'd much prefer the Motorway light.
I was testing last night, and sure enough, I did indeed have Highway light checked on under Byte 10, Bit 3. I un-checked the setting, saved, and still had the Country Light on. I checked it back on again to see if that would change, and nothing. Still country light. This setting does nothing for me.
I was under the impression that the "Highway Light" bit under 4B has nothing to do with DLA or high beams. From everything I've read, that setting simply makes your main beams raise a bit at highway speeds. If that is the case, I don't see what this would have to with the high beams or DLA. I'm thinking there may be another setting that I am missing somewhere and would love to find it and turn it off.
Thanks for your help!
2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
Hey guys, hoping someone can help please, I've followed the instructions and all seems to go well & I can get it to complete with no errors. The lights dance on start up & when they point out there is a big dark space in the middle. BUT I am still only getting the HBA icon, which is the letter A is inside the light. For DLA the letter A should be on the outside right? Can you guys that have it working confirm what the icon should look like please? Prior to trying to enable DLA I had successfully enabled HBA...Im using OBD11 & my long coding is as follows:
Module 09:
0000030000.....
Module 4B:
000000050900084E07104F050A0000.....HAVE ALSO TRIED 000000050100075607106F0500....
Module A5:
000307060000010100022346C150A90098000E300040
I've uploaded a vid plus some screenshots to DropBox
MY18 Tiguan 162TSI, Deep Black Pearl, R-Line, Sunroof, DAP | Ordered 6th Jan 17 | Delivered Nov 17
I’m not sure if this helps, but in my allspace (factory DLA) it only has an ‘a’ inside the headlight symbol on the dashboard- to say the lights are in HBA/DLA mode Vs ‘normal’ mode (no ‘a’ inside the headlight symbol).
So I think your car is doing the correct thing already.
Thanks guys, so just to confirm, your icon looks like this on the dash yeah?
Hi, from my obs on the Tiguan the setting for Byte 10 Bit 3 stops the right hand side light from reverting to normal beam at speeds above 100km/h.
With that setting checked on between 80-100 I get DLA with both sides working on adaptive, steering high beam. At speeds above 100 the right hand side reverts to normal beam only, but the left side maintains adaptive, steering high beam.
With that setting checked off I get both sides with adaptive, steering high beam at all speeds >80km/h
I cannot think of any other changes I have made that might affect this. I took some time to verify this specific change. Did you do a light reset and head unit reset?
Thanks so much for the detailed instructions Phonebooth!
I had attempted it with instructions found on the OBD forum, but it never quite got there.
Followed yours to the T, and it all went through, cleared any errors, and worked perfectly, so much appreciated.
Is there a way to have the default mode (when the DLA isn't active) set to highway lights? (I believe that is the best for forward vision is it not?) As for the majority of my commute there is too much traffic for the DLA to really do it's thing. It is very cool when it does kick in, but when it's not engaged, I still find the distance lit up by the lights to be very short, and would appreciate a more focused beam in front of the car.
(Even since doing this mod I have noticed an improvement in the height of my lights, previously they would only come to the bottom of the rear bumper of most cars/utes, whereas now it comes closer to the number plate, which is what I believe it should do)
If you go into long coding and change it to English and go down there is a setting for Highway_ lights and in mine its enabled.
If you go further down there is another setting for highway_lights ( notice difference) and it is disabled Maybe try enabling that
Moved my post
