Yes, light switch in AUTO and the Headlamp Symbol with the A on it and no faults displayed.
Does it function as intended? There are some posts in the Passat forum indicating that certain light modules are 'parameterised' for DLA.
MY19.5 Tiguan Highline with R-Line & Sound/Vision
This is how it should look It takes a few moments Hit download and wait a bit
Light pattern.mp4 - Google Drive
NAR 2019 Tiguan SEL-P R-Line here, and starting to think DLA may be possible with progress being made with the NAR Arteon. Looking at this and thinking of the economics, why would VW ask for a separate headlight system when you can turn off in coding.
Even states DLA capable, but may be off due to specific countries.
For those with the ROW model, was curious in 4B if the following were checked off and/or if someone can shed light on these features.
In Byte 11 what does dynamical low beam light enabled do?
In Byte 12 what does segmented cornering light enabled do?
Hi Folks, I have a MY20 Polo GTI (Fully Optioned, Oz Market)...
Apologies in advance for the slightly off-topic post, I did originally post here, but have had no luck as yet.
I don't suppose anyone knows, how I can check if it has the hw to do dynamic light assist?
Not just high beam assist (i.e. a high/low auto-switch), but can actually adjust angle of beams.
I'm not sure if it's enabled by default, but there may be the hardware in place for it.
I own/use a OBD11v2 & may eventually get VCDS, as this stuff just fascinates me.
Thank-you!
