Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 86
Thread: my journey to activating DLA on a MY17 Tiguan
    Oct 2015
    No it doesn’t. You have to be in auto high-beam mode for the car to work out when to activate/control the high-beams. Same as normal.
    Mar 2009
    Melb
    I noticed I can leave mine in A mode and light switch in Auto. On a road without street lights at the right speed, the high beam comes on automatically and when traffic or street lamps appear, light reverts to low beam
    Tig 162 R-Line; Audi TT
    Pacific Paradise QLD
    Quote Originally Posted by mr gee View Post
    That is High Beam Assist which is different to DLA
    Get in car put headlight switch on auto and start car lights should do a dance like this
    Light pattern.mp4 - Google Drive
    Mar 2009
    Melb
    Yes, mine does that.
    wnder what extra coding is needed for DLA
    Yours does which?????
    Why dont you just follow the explicit instructions Phonebooth posted because they work
    If it dances like mine you should have DLA if it just drops from high beam to dip right across you have HBA
    DLA splits to leave a car in front in the dark or a car coming toward you also in the dark
    UNLESS you have an ALLSPACE which has DLA standard
    Mar 2009
    Melb
    mie does the same light dance as in your video. I have seen phonebooth's instructions though haven't yet had time to see if I can code it in.
    Is your car a shorty or a Allspace
    Mar 2019
    Massive kudos to Phonebooth for that detailed post, perfectly easy to follow and activated on mine. I had tried previously and failed, but your instructions worked. I did have an error about the dynamic cornering lights, but it went away by itself.
    Mar 2009
    Melb
    Mine's a SWB and did some coding this morning and now have DLA ticked in the setup menu on the Discover Pro. Where can I find menu 4B though
    my journey to activating DLA on a MY17 Tiguan-img_2626-jpg
    Feb 2019
    Perth, WA
    Quote Originally Posted by MickyD View Post
    Glad it worked for you! I found the cornering light errors clear once the ignition is turned off/on after coding is completed.
    You might have module 55 (which does the job of 4B) and may required VCP parameters as mentioned by Kamold.
    MY19.5 Tiguan Highline with R-Line & Sound/Vision
