Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Mk7.5 Golf R exhaust on Mk2 Tiguan
    Dec 2012
    I know there are plenty of forums and conversations about the exhaust swap. Just can't find anyone who has not done the resonator delete or a Stage 1 tune..
    Would there be drone or other irritating sound issues if I cut out the muffler/tips from my stock 162tsi and weld on a Golf R muffler and tips only?
    Valves will be in open position, stock Tiguan system from headers to Golf R muffler (Tiguan resonator and cat in place).
    Thanks in advance!
    Sent from my SM-S908E using Tapatalk
    MY11 B7 Passat 125TDi Highline
    Pearl Mocca Anthracite | Electric and Heated Leather | Folding Mirrors | Sunroof | Adaptive Lighting Package | Footwell Lighting | Park Assist 2 | Lane Assist | RNS510 | R36 Pedals | Scirocco MFSW | Front Lip | 20" Suzuka Wheels | H&R Springs | De-Badged | VCDS Mods | Alpine Mono and 8" Subwoofer
    Apr 2021
    Sydney NSW
    Ok, so by just replacing the rear muffler from a Golf R onto your Tiguan:
    When the valves are closed its all but the same as STD exhaust note.
    When the valves are open, its a bit more throaty (no drone nor loud), it’s only when you do a resonator delete does it makes a huge change.
    I’ve fitted the Golf R rear quad outlet muffler, hooked up the valves & it’s really nice.
    (I’ve also added a bigger turbo & tune)
    Dec 2012
    Perfect. Thanks mate
    Dec 2012
    @Lacksballs just picked up a Mk7.5 exhaust and thought I could lock/tighten the valves in the open position. They currently open and close freely.
    Do you know how to secure them in the open position?
    Attached, photos.
    Feb 2014
    Is there a coding setting/hack to leave them open? IIRC - OBDEleven has an app that does this for the arteon.
    Edit: here's a screenshot from OBDEleven (Arteon).
    Mk7.5 Golf R exhaust on Mk2 Tiguan-screenshot_20230430-180108_obdeleven-vag-jpg
    Apr 2021
    Sydney NSW
    I’m pretty sure on eBay Ive seen a bracket that bolts onto the actuator mounts and clocks in to valve “key way” to lock them open Audi/VW. Or ask the exhaust shop to spot weld them open when they fit the exhaust..
    The tail pipes will need lengthening to suit the Tiguan outlets. The muffler itself is held in the same position by the same mounting system.
    To keep the cost down do the following:
    Remove plastic factory “fake” tail pipe exits from the bumper so the exhaust shop doesn’t have to.
    Wrap the reverse sensors wiring in the rear bumper in heat proof wrap in the vicinity of the new dual outlets. (I think I even rerouted 1 away from the outlet position)
    Dec 2012
    Appreciate the advice.
    Will do mate
    Nov 2016
    Sydney NSW
    I just picked up an MK7 non valve golf r muffler on the weekend.
    I'll be having it installed in the next couple of weeks with a res delete. I'll be asking the shop to flange it so I can easily swap the res in and out.
    Stock 162 Allspace. At some point in the next few months i'll do stage 1 tune and various engine components.
    Apr 2021
    Sydney NSW
    I’m not sure by fitting a non valve Mk 7 exhaust you are achieving anything? Unless it’s an after market R exhaust that does physically doesn’t have the bi modal function???
    Mar 2021
    This has been an unanswered question for quite some time given the number of people replacing their stock mufflers with Golf R mufflers. It looks to me like it's the same muffler on all MQB cars, but with different pipe configurations. You can even see where the pipes are blanked off. I've collected a few images to show this.
    I wonder if you punched 2 holes where the blanks are, would you get the same results as a Golf R muffler albeit without the valves?
    I don't have the ability to attempt this, if someone is about to do a Golf R muffler swap, would you be willing to hack up your stock muffler by making some holes where they're blanked off and seeing the results? it may save you the cost of the Golf R muffler and instead just get an exhaust shop to weld some pipes onto the existing muffler.
    Mk7.5 Golf R exhaust on Mk2 Tiguan-untitled-jpg
