Originally Posted by
Pezzaano
Thanks guys for pointing out the settings in the sat nav. I was everywhere in the vehicle settings to find this setting and couldnt find it. Now it works perfect with the audio disabled. It's nice to have the sign displayed on the instrument cluster. In regards to the stop start, I have seen those cables from aliexpress but I'm the same as you and don't want to try prying off the consoles and leave screw driver marks and ruin the panel. Today I tried to increase the voltage to 12.5 or even 13v and it wouldn't accept those figures. I have read you can disconnect the 2 wire connector at the battery but I don't want to go down that path as who knows what other system needs the battery voltage to function correctly.
Does anyone know of a VW manual or document which has every system and all its sub systems and options that are in the adaptations or long coding pages. I'd hate to think to try nut a lot more codes out you need to have the battery connected to a battery charger. It would be nice if there was a document and you could go thru it page by page and see if there are things you might want to play with.
DONT disconnect anything from the battery as you will stuff up the charging rate and cause more problems.
Do you really think VW would go to the trouble of stopping you from doing things yet publish that sort of stuff to allow you access.
You are dreaming. They are trying to discourage this sort of thing, not tell you how to do it..
Bit of advice if you play too much and stuff it up completely its about $500 to get the car reset to factory.
How do I know? Had to get my wifes Polo reset when its BCM carked it. Only a rough as guts player leaves screwdriver marks on trim. I use the proper tools on mine
