Page 103 of 118 FirstFirst ... 35393101102103104105113 ... LastLast
Results 1,021 to 1,030 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #1021
    Pacific Paradise QLD
    Have you putt the verification code in to get into programming in the module. Ive only got a V1 and it does it
    Error 31 can need the App data cleared from within the app on your phone. Presumably you are using an Android phone and not a piece of an Apple
    Clear data and restart the app
  2. #1022
    Aug 2008
    No I haven't put in a verification code. But I have changed two other parameters no problems. Will look into it.
    Yes Android, Oppo A73. Not sure how to clear data, but I have restarted the whole phone as part of the process.
    Thanks for your help, much appreciated.
    MY19 Tiguan Highline R-Line
  3. #1023
    Quote Originally Posted by Ricka View Post
    Get your phone go to settings/apps /scroll down to OBD!! Open it go to storage,click on it /clear data
    You will have to log in to the app again so hope you have your password
  4. #1024
    Aug 2008
    Get your phone go to settings/apps /scroll down to OBD!! Open it got to storage,click on it /clear data
    OK, cleared the data from the app (I thought you meant that this was done within the app and I could not see where).
    I had to sign in to the account, but no pairing code or device password needed, it just goes straight in.
    Much much quicker to connect this time.
    Successfully defeated Start/Stop using voltage method. Success!
    I noticed in the menu an item called "Deactivation of start-stop function", with options of
    Mode not active (current setting)
    Stop release
    Stop prohibition, no start request
    Start request
    System malfunction
    I just wonder if this would be an even cleaner way to do it, using the Stop prohibition option?
    Anyway thanks for your help, a lesson learned re clearing the data first, which hopefully may help others.
  5. #1025
    Stop release
    Start request
    System malfunction
    Youve got it done so dont try something that doesnt seem to have been done by anyone I can see on several international forums
    There are about 2000 different settings in a Tiguan and I wouldnt touch at least 1960 of them unless i found someone else had done it first.
    It can be beneficial to look through Golf Mk7 tweaks as well as some work on the Tig Some dont like Pace car taillights as the Tig ones are different and lesser quality
  6. #1026
    Stop release
    Start request
    System malfunction
    Hi, but did work the start stop to stop the function?
    Enviado de meu SM-G970F usando o Tapatalk
  7. #1027
    Quote Originally Posted by PapaLeguas View Post
    Just do it with the voltage method which is proven to work and not stuff around with the unknown
  8. #1028
    Aug 2008
    I didn't try it. I used the voltage method and it worked after I cleared the app data.
    It is very good advice to only use tried and proven tweaks. The OBD11 opens up access to so many parameters, many of which are basic to the vehicle's operation. Best to tread very very carefully.
    Having said all that, the "Stop prohibition: no start request" tweak is in fact the identical tweak as the second start/stop tweak on the Golf Mk7 list.
  9. #1029
    May 2017
    Sweden
    In my Tiguan 2017 i had the composition media. The menu looked like the first image and it was "in a line".
    I coded it somehow so the menu structure looked like the second picture, like a "grid".
    I want to do it on my passat now, but I can't remember how i did.
    I didn't change the headunit, it was only coded/adapted with vcds.
    Does somebody know how I can do it?
    Skickat från min SM-G975F via Tapatalk
  10. #1030
    Oct 2018
    Melbourne, VIC
    has anyone tried the 'starting vibration reduction'?
    Select Control Unit 03 – Brake
    Adaptation
    Starting Vibration Reduction
    Set to Starting Vibration Reduction and Torque Limitation to ‘Deactivated’
    Found it on the AutoInstruct site, but curious to hear if it makes any noticeable differences.
    Says it stops the automatic braking intervention during wheel hop scenarios.
