It was disabled (or not included) in the Allspace for safety reasons. Presumably so kids or rear row passengers would not get caught by the driver closing it without looking. Havent heard of it being able to be enabled in an Allspace
Has anyone tried the obdeleven app for "rear lid control" in an Allspace to enable you to close the boot from the drivers door switch?
"Turn ON or OFF function to close rear lid from remote or switch in the driver door" sounds right and figure it should be able to be enabled as its default on the 5 seater, but realise a few of the apps don't do what you expect...
edit: The thread on proboards was a bit inconclusive to my newbie brain. Suggests can be done, but only through making it think it's the 5 seater? Close rear lid with remote control | OBDeleven
PSA: there's a new OBDeleven app which makes the start/stop button illumination fade in and out before you turn on the engine. very simple. very cool.
OK, posting in the correct thread now.
The link at the start of this thread shows 4 methods:
* Gateway Coding
* Prohibition
* Temperature
* Voltage
The first 3 methods have been blocked by VAG, even in our My19 Tig.
Only remaining option is Module 19, Byte 03, where it looks like you can untick the blue box for "Start/Stop system with recuperation installed (PR7L6)". Not game to try it without some knowledge that it is ok to do this. There is also a bit by bit alternative at that point.
Would be interested to know if anyone has tried it.
MY19 Tiguan Highline R-Line
