MY18 Tiguan R Line Black-162 Highline TSI
Drivers Assistance Package - Sunroof - Tow Bar
Ordered July 17 Arrived December 17 Delivery Jan 18
Its as plain as the nose on your face as under the big digits which is the first BIT in the BYTE you are on is the BYTE number you are on.
Top row 00
under that it says BYTE 21 or whatever you have scrolled to
Hexadecimal always starts at 00 AFAIK
You are both getting definitions mixed up which can only lead to confusion
The bottom number is a BYTE which has a certain number of BITS which are the numbers in the top row..
Try to get it right or instructions will be incorrect
While it doesnt quite follow the protocol of 8 bits to a byte it is basically the same thing
Bits and Bytes
Why didnt you just use the APP It works.
If you havent got enough credits Open the program every 24 hours and you get a free credit and if you open 5 ads you end up with 6 credits a day. Ive got 630 ATM for virtually doing nothing.
Yes l did mix myself up with the message from PDMJO, bit 1 means bit1 etc. Byte numbers bring up the difference pages of bits.
I hope that is right.
I have redone again and all appears to be working except the fault light assist in dash centre comes on when pushing stalk forward
I did originally use the app but had to reverse it as I had no high beam even pulling back the stalk for highbeam flash didn't work.
Where are the ads?
Thanks
Hi all, i have an MY20 Tiguan Allspace Highline, S&V, R-Line.
I purchased a Ross-Tech cable and have been making a few changes.
So far i have managed to do the following;
Adaptation changes;
IDE06419-Driving profile switchover
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen
IDE04159-Deactivation of start-stop function - didn't work
IDE12467-Tubes illustration
IDE05111-Fee-based traffic information (TMC) - yet to confirm if this worked
IDE04158-Activation of start-stop function - this didn't work
IDE06588-Ignition active message: actuator
Long coding changes;
Overtaking right prevention active
Sat Nav initial disclaimer
display volume to be replenished
display acceleration
The one thing that i desperately want to change, is the stop/start function.
Does anyone with a new platform vehicle have a solution for this?
I looked for the temperature method, but couldn't find anything.
latest coding form the car below.
Tried to put in coding but website tells me it is too long.
