Page 93 of 118 FirstFirst ... 43839192939495103 ... LastLast
Results 921 to 930 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #921
    Feb 2019
    Perth, WA
    Enable Auto High Beam (Light Assist)
    According to the full spec sheet of mine it says this
    Dynamic Headlight range control with cornering lights (AFS)
    They change what they call things so who knows what we have
    I've enabled that already.
    Yep my spec sheet says the same thing. I think that means the lights pivot slightly as you turn the steering wheel. There's also that small cornering lamp in the headlight assemblies which activates when you turn the steering wheel beyond a certain point or activate one of the indicators.
    From my understanding DLA has the high beam on all the time and uses the shutters to divert the light around passing cars/cars in front.
    No idea why they have to make it so confusing.
  2. #922
    Pacific Paradise QLD
    Quote Originally Posted by phonebooth View Post
    Read pages 102 -104 of your manual and see if you can see the high beam icon with the A in it when you push the stalk away from you
  3. #923
    Feb 2019
    Perth, WA
    Yes I have that because I activated HBA. I believe they share the same icon.
  4. #924
    Feb 2019
    Perth, WA
    I've been actively posting in the Passat B8 forum regarding Dynamic Light Assist getting some advice from fellow forum members.
    So for the benefit of all us Tiguan owners, I've managed to get Dynamic Light Assist (DLA) activated in my '19 Tiguan SWB Highline w/ Sound & Vision + R-Line.
    Dynamic Light Assist for more information.
    MY19.5 Tiguan Highline with R-Line & Sound/Vision
  5. #925
    Nov 2016
    MAPLETON Qld
    Good to see you persisted instead of throwing in the towelMk2 Tiguan VCDS Tweaks
  6. #926
    Feb 2019
    Perth, WA
    For those who are interested, here's a video of the light startup sequence and a brief demo of what DLA looks like.
    Seems to activate around 60-65km/h on dim roads.
  7. #927
    May 2019
    Yarra Valley, Vic
    Fantastic phonebooth - that is awesome news. To me the SWB not having DLA was one of the biggest letdowns when purchasing my car - considering my 2017 GOLF GTI has has it. Being a complete OBD novice, I will now have to buy an OBDeleven (waiting for the IOS version) and will give it a try. In your opinion, did you first have to code the HBA before you could go onto coding the DLA, or could you go straight to coding the DLA?
  8. #928
    Feb 2019
    Perth, WA
    Quote Originally Posted by davman View Post
    Hi Davman,
    I already had HBA activated when completing the steps. I'm not sure if this makes a difference or not.
    Most of the steps required to activate DLA overwrite what you've done for HBA. Especially the central electrics control unit adaptions.
  9. #929
    Aug 2018
    Anyone using an OBDeleven V1 in a Tiguan - do you need the extender, or is the port in the car accessible enough to not require the extender?
    2018 Allspace 162TSI R Line
  10. #930
    Nov 2016
    MAPLETON Qld
    Quote Originally Posted by iDiesel View Post
    It’s easily accessible.
