Page 90 of 118 FirstFirst ... 40808889909192100 ... LastLast
Results 891 to 900 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #891
    Pacific Paradise QLD
    Quote Originally Posted by PDMJO View Post
    I’ve got the SWB.
    Like I said, all I remember is that the adaptations were called something different to what’s listed in the guide, so I modified the equivalent one.
    You can go through "History" in OBDII and see what it was that you did. mIght be helpful for us
  2. #892
    Oct 2018
    Melbourne, VIC
    I’ll try remember when I get home from work tonight.
  3. #893
    History is in your phone Dont need to be connected to read it. Whenever you can will be good though
  4. #894
    Oct 2018
    Melbourne, VIC
    Maybe those with the new AID / a proficient understanding of Russian can shed more light on this, but it seems like the interface can be adjusted?
  5. #895
    Oct 2015
    I know that via obd11/vcds you can change which dash theme is displayed on the v1 AID- from several vw models.
    This looks to be the same?
  6. #896
    Quote Originally Posted by Simonr23 View Post
    Usually its coded for the model you get it in mine has the Rline logo
  7. #897
    Oct 2018
    Melbourne, VIC
    Ok so here’s where I deviated from the AutoInstruct guide:
    I either did that instead of ticking the bytes, or I did it in conjunction with it... but I believe I did the former.
  8. #898
    Thanks for that Will have a look at mine but mostly I didnt get that far into the coding to be able to.
  9. #899
    Oct 2018
    Melbourne, VIC
    To clarify on my own post, I seem to have done this instead of the front sensor control unit byte.
  10. #900
    Have changed that but I guess I will have to try to recode the whole thing as after I got the 'Not supported" notice it looked like the settings I changed had reverted back to original. Will be using it ant night on Sunday so we will see
    UPDATE
    SUCCESS
    Had to change a couple of things Like extra headlight LED and do what you said and it shows the correct symbol in the dash anyway, when I have headlights on and push the stalk away from me
    couldnt figure out how to get the A5 to show in hex but worked out little sign in top of phone screen changes it into hex from English.
    I changed it as you did but also did the hex settings and iit seems to have done it Now to see if it works on Sunday
    To be perfectly honest in the video that supposedly shows it working I couldnt tell the difference between it on or off
