Page 87 of 118 FirstFirst ... 3777858687888997 ... LastLast
Results 861 to 870 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #861
    Pacific Paradise QLD
    I did the battery charge mod yesterday. Said it accepted it but when I do the hold the button down i get a copyright message instead of the Battery level.
    Any ideas ???????????
  2. #862
    Aug 2017
    Uk
    Check your earth tab on your battery? Is it a little box or just a tab and bolt
  3. #863
    Quote Originally Posted by Jap View Post
    Its this
    Attached Thumbnails Attached Thumbnails Mk2 Tiguan VCDS Tweaks-20190519_090000[1]-jpg
  4. #864
    Jun 2018
    Melbourne,Victoria
    Had my car in for a service today and found they have reset my bypass to the autostop function. Traffic alerts were untouched. Has anyone else had this happen during a service ?
  5. #865
    Apr 2017
    Quote Originally Posted by MrSteve View Post
    I assume they do the reset as the faults coming up.
    Not a big deal.
    You can always mod back to what you like.
  6. #866
    Which bypass did you do. Dealer did a software update on mine last week and it hasnt altered any of the tweaks i did
  7. #867
    Jun 2018
    Melbourne,Victoria
    I did the voltage change to disable the engine autostop. I will connect up to the car and see what the value is now, and then change it back.
  8. #868
    So did I and whatever software they updated didnt change it. Was something to do with parking sensors not working properly on some vehicles
  9. #869
    Have tried to get speed sign recognition going using the app several times and it hasnt worked
    This afternoon while playing I went into Module A5 Front sensors Driver Assistance System/Road sign detection Fusion Mode
    Was reading Road sign Fusion
    Changed it to the option which is Road sign Detection.. NOW IT WORKS
    Seems the App didnt do it properly
  10. #870
    Oct 2015
    Glad you got it sorted. Changing fusion mode is one of the steps to activate it- I’ve only done things via coding, for each feature I’ve enabled.
