Page 81 of 118 FirstFirst ... 3171798081828391 ... LastLast
Results 801 to 810 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #801
    Sep 2011
    Melbourne, Victoria
    Is there a way when stop / start is on to change the setting for how car the car infront moves before the engine turns back on?
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
  2. #802
    Aug 2018
    Are you wanting more or less delay?
    2018 Allspace 162TSI R Line
  3. #803
    Sep 2011
    Melbourne, Victoria
    More or not have ot turn the car automatically back on
  4. #804
    Feb 2019
    Perth, WA
    Am I right in saying that;
    Dynamic Light Assist - Dips beams depending on oncoming traffic.
    High Beam Assist - Simply high beams on/off automatically dependent on traffic.
    Has anyone successfully implemented Dynamic Light Assist on their MY18/MY19 Tiguan Highline with R pack? Reading back through this thread it seems like there was mixed results with fault codes appearing etc.
    Also the MY19 I'm expecting advertises "dynamic cornering lights" in the specification brochure. Is this a different system to dynamic light assist?
  5. #805
    Apr 2011
    Perth, WA
    Quote Originally Posted by veew View Post
    I just went to the car to try this. Turns out none of the browsers on my iPad or iPhone could load the image so I decided to type out the text for those with similar issues.
    Direct Acceleration - Throttle response
    With this mod, you can change the behaviour of the accelerator. Option B provides a more linear acceleration without sudden deliveries.
    1. Module 44 - Power Steering (Code 19249)
    2. Adaptation
    3. Select - switching driving profile
    Choices:
    A - Gradual, controlled by time
    B - Directly controlled threshold value
    Just tired it on my 2018 Allspace Rline and it works awesome. I usually put the gearbox into Sports when turning on the yellow light due to the throttle lag. Also find when the car changes into 3rd you have to add some more throttle to keep the acceleration constant. after the mod the throttle is more responsive.
  6. #806
    Aug 2017
    Uk
    Quote Originally Posted by INASNT View Post
    Module 13 ACC
    adaptions
    Expanded restart function:
    Switch from on to off, then the car will not start if the car in front moves
  7. #807
    Sep 2011
    Melbourne, Victoria
    Quote Originally Posted by Jap View Post
    Module 13 ACC
    adaptions
    Thanks mate.
  8. #808
    Dec 2017
    Module 13 ACC
    adaptions
    This might just be the solution to my irritation.
    When I'm in the front at red lights waiting and the engine starts automatically due to pedestrians walking past or even cars moving past at a close distance.
  9. #809
    Aug 2018
    Quote Originally Posted by phonebooth View Post
    DLA - turns the lights in the direction of your steering wheel when cornering
    HBA - automatically turns on high beam, and dips it (or parts of it) when the camera picks up on coming cars
    Yes, this uses either the fog lights or a small light built into the headlights (depends on the model) to light up the side of the car approx 60 degrees off centre as you are cornering. The light comes on less than 30k/hr with indicator on
  10. #810
    Feb 2019
    Perth, WA
    Thanks iDiesel!
